Can spearker box give out ??
Username: Texas_bass
Houston, TX
Post Number: 736
i noticed my sub was making funny nose and went to go check it out and the screws that hold my port have snapped and letting the mdf vibrate really bad but ive got 4 screws on top and 3 going down either side so the screw and the glue is gone should i just put some extra screws in and get started on a new box cause it will probably gonna happen again
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5431
Screws are only going to make the enclosure weaker (the MDF specifically) It does not sound like you have alot of screws anyway so It's weird that your port is loose. I would put some more glue on it and just clamp it until it dries. What glue did you use on the enclosure?
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 318
my friend bought a pre-fab slotted enclosure (sounded like sh!t) for his BL 15. Within about two weeks the front baffle was blown off and the only thing holding it on was the carpet. needless to say, it is in a better home now ( i built him a new box for it lol)
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16067
pics wud help....
Houston, TX
Post Number: 737
ill get some pics up in a bit i gotta find my camera (in the middle of moving) but ill get some pics up soon
Username: Dustin3
Post Number: 5432
Titebond works the best actually. Since it's actually a "wood glue"
