I usually get either of these messages after every 10 - 20 minutes on K Box. Tired of those, i updated to the latest bin file of 1 Mar 2010 but still got either of these matches. When i go to the menu/Network . i see it is trying to get IP or internet connection again. Any idea why ? I have a Powerline Adapter and pretty sure its working. Tested it many time through my laptop and other PC too.
If you have a good internet connection you should not get that message every 20 minutes. 1. Possibly the channel you are viewing may be the reason. Try keeping it on 200 and see if the same thing happens. 2. Try a router connection using ethernet cable. Even if the distance is the reasone why you have powerline adaptors, bring the receiver closer and use direct ethernet connection to see if the problem occurs. 3. It might be an issue with your ISP and internet connection.
I have this Powerline adapter since 6 months. It has just started , yes my router is very far from receiver, and its in such a place that i cannot bring ethernet cable , if i do it will look very bad
Even if the distance is the reason why you have powerline adaptors, bring the receiver closer and use direct ethernet connection to see if the problem occurs.
