RE MT 15
Username: Dylan9999
nvm figured this out i dont know how to delete post lol
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 341
http://www.dealercostcaraudio.com/reaudiomt15.aspx
thats just a price.
the sub is custom made so you can choose what ohm you want it to be (dual 1, dual 2, etc.)
for amps, i've heard of people using anything from 2000 to 4000 and up to 10k for SPL burps
Username: Dylan9999
Post Number: 7
ohh ok thanks. yea i was thinking a dual 2 with a kicker zx2500 or something would pound. wut is the difference with ohms like would it be better running it on 2 ohms or 1? so say i had a dual 1 and ran it at 2500 2 ohm or would it be better to have a dual 2 ohm n run it at 2500 1 ohm? cuz from wut i understand it either has to be half or double the ohm the subwoofer is right?
Post Number: 349
as long as your amp is 1 ohm stable, its fine to run it at 1 ohm. If not, i'd run it at one ohm.
and you are correct about the half or double ohm theory lol
Username: Dylan9999
Post Number: 8
no i want spl but with some sq to. i dunno everyday im discovering more n more subs that im hearing are better then the last one i hear about so im just researching a few months before im actually gonna go buy my equiptment
