BernyMac needs new subs for the truck
Username: Bernymac
Phnom PenhCambodia
Post Number: 4834
Sup guys. Back when I put sounds in the truck in 08. I had a 12" ssd. Well, everytime it hits low freq's the sub would cut out. I think the box would be better suited for a 10".
Heres what the box looks like
Its roughly 1.4cuft total (no sub/port disp)
So imagine after sub and port disp, its probably only 1cuft. Better suited for a 10".
What do you guys think I should do. Cut out a mdf piece and customized the box for a 10" subwoofer. Or customize it for 2 10" sealed.
Username: Insearchofbass
York, Pennsylvania
Post Number: 13659
why not just go sealed with the 12
Username: Bernymac
Phnom PenhCambodia
Post Number: 4835
I tried plugging up the hole but the sub still cuts out! So stressed when I think about it lol.
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16033
when u say "cut out" u mean bottom out ?
build a sealed new box ...
Username: Bernymac
Phnom PenhCambodia
Post Number: 4836
yeah bottom out. I tried sealing up the box, and sub still bottoms out. Its a fi ssd flatwound. Don't think its made for sealed box's.
Username: Poprocks
Post Number: 316
Maybe try some new T3 Audio T200/T400/T600.
Username: Bernymac
Phnom PenhCambodia
Post Number: 4840
I found out that my problem isn't a subwoofer problem. I hooked up a different sub in a different box that my friend has and it did the same thing in my car, which never happened in his car. The sub isn't bottoming out, bc it stops moving. Plus I'm only giving it 500rms. So it would stop moving for 1-2 seconds and resume playing. When the sub cuts out, I look at the amp and it shows no sign of clipping or turn off, amplifier stays on the whole time.
