Kbox K2 HD
Username: Koolieman20
can any one please tell me when codes for the kbox hd will be up and running??? i'm thinking of buying this box, any thoughts?
Username: Guanajuatos_best
Post Number: 320
Feb. 30.
I think
alright thanks a lot for the estimated date.
Username: Saqeeb9000
Post Number: 6816
if i was you.. i wouldn't spen $ 400 on hd rec...and especially kbox .after what they left their customer hanging ..with no good explanation...
spend on sd .. buy nano2 or kbox ..
but it would be foolish to spend $ 400...
get may be 2 different brands is worth instead of buying hd...
people who bought nf hd are regrettting now..
Post Number: 321
I would say that if you want to get DN hd, it would be better to get a sub. Im thinking about sub for the world cup, I sure want to get one of those 3D tv's and watch a 3D game.
Username: Sump
Post Number: 935
Kbox HD file is out ...
nfusion has a history of F'ing its customers .ie nova ..... kbox does not ...kbox has ALWAYS been slower to fix or put up channels, but whne they do ususally it is watchable .. IMHO
Username: Nydas
Post Number: 18359
kbox k2 HD has only a factory file. As far as I know there has not been a release of a file that would be considered good enough for IKS.
alright thanks a lot guys! i appreciate it very much
Username: Sump
Post Number: 938
One step at a time Miss Nyda ....
the bigger question is about the HD card, boxes are for sale but no mention anywhere about the card
so wait....in order for the kbox hd to work with the iks system a HD card is needed??? whoa...
Username: Sump
Post Number: 939
Every HD box in the hobby needs the extra card .... usually 75 to 100$
where can i buy a card if need be? any links u can provide?
Username: Sump
Post Number: 942
that is the million dollar question ... as i stated in earlier post ..
"the bigger question is about the HD card, boxes are for sale but no mention anywhere about the card"
so some of us are baffled with this dilema
Username: Nydas
Post Number: 18392
HD receivers need 8SPK cards inserted. It used to be that it was a requirement only of one of the two majors (I forget whether it was DN or BEV). However, for the past several months both providers' HD broadcast require a 8SPK card if you are using a FTA HD receiver. when you buy a FTA HD receiver, you should check if it has this card or not. If not you buy one.
They cost about $200, but I haven't checked the prices lately.
Username: Sump
Post Number: 945
Yes as i said earlier to 75 to 100$
49$ SV
http://cgi.ebay.com/A-1-8psk-Module-Board-For-Sonicview-8000HD-8000-HD-A1_W0QQit emZ270492078214QQcategoryZ67887QQcmdZViewItemQQ_trksidZp4340.m8QQ_trkparmsZalgo% 3DMW%26its%3DC%26itu%3DUCC%26otn%3D20%26ps%3D63%26clkid%3D8278609416314645700
49$ Nfusion
http://cgi.ebay.com/NFUSION-HD-SK900V-8PSK-MODULE-ADAPTER-MADE-IN-KOREA_W0QQitem Z230445176106QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item35a79a552a
Username: Sump
Post Number: 948
WOW New HD file out !! in addition to the factory file
