What is better 2 ohm or 4 ohm sub?
Username: Gutteer
Post Number: 19
comments please ive heard several different thing and would like the truth
Username: Insearchofbass
York, Pennsylvania
Post Number: 13578
it depends on what final ohm load you want
York, Pennsylvania
Post Number: 13579
and how many speakers your going to use
York, Pennsylvania
Post Number: 13580
sometimes it does matter for motor strength though....just look at soundsplinters website and fi's website...youll see a difference in the listed motor strength
Username: Jones82joshua
Yankton, SD USA
Post Number: 100
find some subs that you'd be interested in and check out the t/s specs. look for bl and fs. it all depends on the application, your amp, how many subs, etc. and just because the t/s are slightly different, in most cases, I'm sure you wont notice an audible difference.
York, Pennsylvania
Post Number: 13581
right....motor strength is listed under bl
Username: Gutteer
Post Number: 20
well my friend is saying that 2 4 ohm alpine type Rs would be better than 2 2 ohm alpine type Rs
York, Pennsylvania
Post Number: 13603
you would have to compare their stats to know for sure but you also want to make sure the subs can be wired to a final ohm load that you need to get the most power from your amp
York, Pennsylvania
Post Number: 13604
two 4 ohm dual voice coil subs can be wired to 1 ohm or 4 ohms
two 2 ohm dual voice coil subs can be wired to .5 ohms or 2 ohms
Username: Gutteer
Post Number: 21
ok can you just explain it i have no idea about the ohm load and such
York, Pennsylvania
Post Number: 13611
what amp do you have and what model
Username: Gutteer
Post Number: 22
these are the specs for the 2 and 4 ohm
2 ohm
Power Handling
Power Range: 200 - 500 Watts
RMS Power Handling: 500 Watts
Peak Power Handling: 1500 Watts
Dimensions
Mounting Depth: 195 mm (7.7'')
Mounting Diameter: 275 mm (10.9'')
Displacement: 0.071 cu. ft (Front Mount)
Added Volume: 0.085 cu. ft. (Reverse Mount, Magnet Out)
General
Frequency Response: 23Hz - 500Hz
FEATURES
Diaphram
Material: Kevlar Reinforced Pulp Fiber
Design: 2-Piece Structural Parabolic
Surround
Material: Injected Molded SantopreneA?
Design: High Amplitude Multi-Roll
Spider
Material: NomexA?
Design: Mirrored Progressive
Voice Coil
Material: 180A?C High Temp Wire on Spiral Cut Aluminum Former
Design: 4-Layer Dual Voice Coil
Motor Structure
Pole Geometry: Compound Radius Curve (Patent #6,639,993)
Configuration: Radial Vented VC Heat Sink and Airflow Management System (Patent Pending)
Frame
Material: Cast Aluminum
Design: Perimeter Vented Heat Transfer (Patent Pending)
Terminals
Layout: One Side
Design: Heavy Duty 8 gauge Push with Housing, Banana Plug Jumper
Tinsel Leads
Design: Reinforced Layer Spider Integration (Patent #6,810,988)
Gasket
Design: Concealed Mount Gasket System
4 ohm
SPECIFICATIONS
Power Handling
Dimensions
General
Frequency Response: 25Hz - 500Hz
FEATURES
Diaphram
Surround
Design: High Amplitude Mutli-Roll
Spider
Material: NomexA?
Voice Coil
Motor Structure
Frame
Terminals
Layout: One Side
Tinsel Leads
Gasket
York, Pennsylvania
Post Number: 13612
to make this easier tell me what amp and series you have
Username: Gutteer
Post Number: 23
at the moment i have 1 mtx rt 502 amp im trying to get a Kicker 06ZX4502- 2/1 channel Amplifier
York, Pennsylvania
Post Number: 13616
with the power you have and are going to have get one dual 2 ohm alpine sub and wire it to 4 ohms bridged at the amp
York, Pennsylvania
Post Number: 13617
http://www.rockfordfosgate.com/rftech/woofer_wizard/1_2ohmDVC_4ohm.gif
Username: Gutteer
Post Number: 24
ok well the thing is i dont want the 2 clips i just want 1 set of positive and negitive
Username: Bonhamd
Traverse City, MI
Post Number: 2087
well all type Rs are DVC
so 1 set of pos and neg is out of the question on the type R
why does it matter anyways?
Username: Gutteer
Post Number: 25
ok i didnt know well thats fine then and it dont matter
Username: Cwruck
Post Number: 61
i have a question. lets say you buy 2 subs and the sub is only made in dvc 4 ohm, but you only want to run it at 2 ohms instead of 1 ohm. can you just wire each sub individually in parallel to get a final load of 2 ohms? like you have a single box for both subs but you just wire each one to its own terminal and hook it up to an amp like the jbl gto 15001. since that amp has 4 inputs. the reason for doing that is 1 the subs can only be bought in dvc 4 ohm not dvc 2 ohm. and 2 that amp wont work in 1 ohm but only 2 at the least. that would work right?
and another question, what happens if you have 2 alike subs like rockford fosgate t1's but one is a dvc 4 ohm and the other is a dvc 2 ohm. what would be the wiring options? Thats something i have been wondering for a long time now
