I posted this in the wrong forum first, my bad! So here's what I need help with: How would I go about wiring a 4 ch amp and an amp for my sub( when I get it) to a stock head unit. I like my 6 disc changer so I don't want to switch it out. I know wiring the 4 ch I would just get a couple of line converters, but adding a sub amp has me confused! I am getting a dual amp install kit also, so all I need is how to wire it to the head unit!! Thanks in advance!
run all your wires as normal. get a power distributor to split your power to the two amps. run rca's from your ouput on the 4 channel amp to your input on your mono amp. run a remote wire from the remote trun on on the 4 channel to the mono amp. ground the two amps in seperate places and you are done.
