A trade i need help on respond as soon as u can plz
Username: Gutteer
2 12" audiobahns in a ported box alpine v12 amp 2 10" alpine type Ss (might be blown guy hears a rattling sound when they play) and a 10" dual bandpass box?? is this good for one Alpine type X
Username: Tejcurrent
Post Number: 2132
No.
Username: Gutteer
y id be getting all that stuff for trading away 1 alpine type X
Username: Skdooley
Roanoke, VA Usa
Post Number: 299
The alpine type X is a good sub. A pre fab box is no good, anything audiobahn is no good, the type S' are a base model line. Alpine amps are nice, but why have a decent amp with no decent subs to play.
Username: Gutteer
y does audiobahn suck??
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5396
1. they sound like sh!t
2. poorly made
3. overpriced
but mainly sound like sh!t
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4198
it's a well-known fact audibahn uses chrome and flames to sell their subs... the amps aren't totally bad for the money but the subs all stink. they sound muddy and the build quality is not up to par with other companies.
Username: Gutteer
o ok well thank you for the input if u have any other advice id appreciate it
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2961
If a type S is blown it's worthless imo. Not worth fixing.
What alpine amp is it? v12 is just a series not a specific model. If the AB's are immortals then It might be worth it only if the type s's are not blown. I say this just because you could part everything on ebay and mayybbe come out better.
Username: Gutteer
Post Number: 7
well im lookin to just keep what i want for a system and sell the rest
Post Number: 2133
My reasoning is you could possibly be trading a good subwoofer for a bunch of crap.
Just have to assume the audiobahn stuff is junk, the amp is probably one of the lower output models judging by the subs. They type-s subs may or may not be fine and the box probably sucks.
Overall you have a much better chance of sounding good/getting loud with the 1 type-x imo. At least you know it works.
Username: Gutteer
Post Number: 8
i have 2 of them i cant afford 2 power them thats y i want 2 get rid of them
Post Number: 2135
Sell one and buy an amp.
Why would you get subs you can't afford to power? I've never regretted doing something right even if it was expensive I was happy with the results, but I've kicked myself in the azz every time I cheaped out or went the easy way.
If you can't wait to afford power seriously just run 1 sub and build a nice ported box. If you're going for SQ 1000w on a single sealed type-x sounds great to my ears anyway.
Username: Gutteer
Post Number: 9
true well would some one help me with box dimensions for a single or something cuz id have no idea wut 2 do id like the deepest hardest bass i can get with it
Post Number: 2136
Need the dimensions of the trunk or area where the sub will be. I like the sound of a sealed type-x in about 1-1.2ft net. Ported go about 2ft @ 32hz.
Username: Gutteer
Post Number: 10
thats the thing i dont have a car yet just a truck and thats not gonna even fit
Username: Gutteer
Post Number: 11
and i didnt buy them i got them from my father as a gift because he no longer does the sub thing
Username: Kdryden
Post Number: 141
"thats the thing i dont have a car yet just a truck and thats not gonna even fit"
Username: Gutteer
Post Number: 12
i dont have a car 2 put them in so the and the subs wudnt even come close 2 fitting in my truck
Username: Gutteer
Post Number: 13
bump
Username: Skdooley
Roanoke, VA Usa
Post Number: 300
Is your truck a single cab or do you have any space behind the seats? If you have some room I'd say you could sell those 2 type X woofers for a decent amount of money. Take that and get you a decent quailty amp and maybe 1 or 2 smaller subs, 10s or even 8s depending on the room you have, and go from there. If you're a little short on money after selling the type Xs then save up some dough and do your set-up over time. It's better to get good quality stuff over time and do it right then get whatever you can and just throw it together. If you're looking for a good amp for a reasonable price, check out Audioque or keep your eyes open on forums with people selling their amps.
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16026
audiobahn has been out of business about 2yrs going which speaks volumes about them ....
Post Number: 2137
Why don't you measure the dimensions you have for subs? If you can't fit 1 12 sealed what were you going to do with the ported or bandpass enclosure you were considering trading for?
If you can't fit the type-x 12s then sell them and post up a budget of what you get from them to buy a new setup. We can suggest equipment from there.
Username: Gutteer
Post Number: 14
im not looking for a setup for my truck i want them sold so i can get 2 type Rs
Username: Insearchofbass
York, Pennsylvania
Post Number: 13558
how are you going to have room for the alpine type r's?
Username: Gutteer
Post Number: 15
im getting all my stuff ready before i have my car so i can just hook it up and go
Username: B3n07
Louisville, Ky USA
Post Number: 1184
the type x will sound a lot better and be alot louder in your car then some type Rs
Username: Gutteer
Post Number: 17
i got that part i just want something i can afford 2 power and cuz the type Rs rms around 500 last time i checked and i have one 500 watt amp already i just need one more
