Direct Tv sub sharing need help
Username: Gocuse3
Post Number: 53
I'm looking at getting direct tv, my friend live's in the states and im in canada , when i go to activate the receiver's do i have to activate them from his home in the u.s. or is ok to activate them at my home in canada
thanks
Username: Grnnc
Post Number: 139
Do you have Direct tv service in canada? If it is not available in canada ,then you can activate them in us and take one sub with you.
Username: Gocuse3
Post Number: 54
we do not have direct tv service in canada, we can pick up the signals no problem
Username: Nydas
Post Number: 18260
If you have the right LNBs (DTV LNBs are different from DN LNBs) you can scan in Canada. You may be able to use Starchoice LNBs.
I am told that you should not use telephone connection to the receiver from Canada.
If you get it programmed in USA, you will still have to rescan it from your location.
Username: Lklives
Post Number: 16086
sub sharing = sharing a sat providers LEGAL subscription's monthly costs, and provided receivers and cards..
For Numb Nuts nalin....lmao...U CANNOT subscribe to American sat provider Directv (DTV) in Canada!...and U cannot hack DTV either or use FTA equipment, and MUST use receivers provided by DTV, which ya don't scan!....so SCANS are a MUTE point...and a VERY IGNORANT answer reply by NN....and BTW, DTV and DN do use the same LNB's, depending on which satellite U want..(for example, the DTV 101W sat, requires only a very simple circular LNB)
The DTV (leased or purchased) legal receivers with card inserted/married to it, can be activated in anyplace in North America, regardless of where the account owner lives in the US....so yes U can activate the receiver and card in Canada for an American based account...however since the receiver and card are being mailed/given to someone in Canada, its best the account owner in the US "activate" the receiver and card FIRST for you, prior to sending/giving it to ya, just in case there are any gliches onces its activated, which does occur sometimes.....then no need for U to activate it in Canada, and be stuck in the "middle" between the account owner and DTV techs, if there's any problems when activating.....believe me, its not uncommon to have some missing channels or no TV "sometimes" (maybe 25% of the time) when the receiver is initially activated..stuff happens, so if ya can, have the account owner activate it first before he gives it to ya..
The receiver and cards are activated thru the satellite signals in the sky by Directv personnel, once the account owner calls DTV and says he's ready for "activation"....NEVER plug in the phone lines either to the shared receiver/s, they will get ya in trouble, the phone lines are used only for DTV to bill your PPV purchases, so no need for phone lines...the account owner can plug his phone lines in, but NOBODY else.....so have the account owner order all PPV's ONLINE, then ALL receivers on the accounts will "mirror' the PPV and it'll be available to ALL receivers on the owners account..
as far as the dish, if must be of the same type (LNB's) and alignment as Directv...normally U can catch 95% of the DTV channels by aiming a circular LNB at the 101 sat...for HD channels, then other LNB's and alignments are required...U will NOT get the local channels, so don't be surprised, unless ya live very very close to the US DTV account owner..
Username: Cntrlaltdel
Post Number: 309
I couldn't have said it better myself LK... only thing I'll add is you can pick up the HD DTV dishes on ebay or most satellite stores in Canada if you're getting an HD receiver sent up.
Username: Nydas
Post Number: 18263
L K: YOU are an idiot. People in Canada are getting their relatives to send them a DTV receiver. And the subscription is paid by the relative in USA. It is happening hundreds of times a month. You are living in florida and don't know a thing.
The person had a simple question, - should he get it programmed and scanned in USA. I have personally watched a DTV receiver being used in Canada - brought from New Jersay and they had to rescan,.
So YOU stop contradicting me. I have seen all the things I am talking about.
I also said that he can pick up StarChoice LNBs because they are often identical to the LNBs of DTV.
You are confusing receivers and LNBs. The receiver will be bought or obtained somehow in USA. It can be and usually has to be rescanned after it arrives in Canada.
Get this simple fact in your little head. New York/New Jersey area is almost the largest city complex in the world and GTA (Greater Tornto) is another extremely large City complex. IN BOTH AREAS reside many thousands of Indians with relatives flowing accross the border in large numbers, incomprehensible to your little mind. The operation that this questioner had is happening hundreds of times.
Go and take a dive in Largo Key. You have turned a simple question into a foul mouthed warring match - totally unwarranted. Keep your installation knowledge to help your friends living in the little corner of America where you live.
Username: Nydas
Post Number: 18264
Gocuse: I have given the technical facts. I am not going to advice you about what is legal and what is not.
Username: Lklives
Post Number: 16087
NN..your reply is 100% wrong!..NO SCANS!..and U have once again made a fool of yourself!...providing 100% total bogus incorrect info...
Username: One_eye_jack
Post Number: 556
Nalin Nyda....Stop bashing and aqrgue with our knowledgeable
members. You are confussing our guest Gocuse.
Lk and Bill Hunter are correct I do think you should apologize.
You said that ............So YOU stop contradicting me. I have seen all the things I am talking about.
............ NOT SO wrong info.
There are two kinds of satellite lnb. One is called circular feed lnb and the other one called linear feed lnb. Linear feed IS NOT compatible to circular feed. Circular feed lnbs work for the following satellite systems: Dishnetwork, Bell ExpressVu, and Directv.
Linear feed lnbs works for: Star Choice and Free to Air signals. Please be aware when I mention FTA (free to Air) I mean the actual free to air satellites.
For Circular feed satellite Lnbs, the following satellites will work: Nimiq 91, Nimiq 82 (Expressvu), Dish network (119W, 110W, and 61.5W) and Directv (101W)
For linear feed satellite Lnbs, the following satellites will work: Anik F1, Anik E2 (Star Choice), 121W, 97W and all FTA satellites.
Username: Gocuse3
Post Number: 55
Thanks guys
the person im sharing with is just across the border from myself, so to read it properly i can have the receivers activated in canada and i shall be fine , no way direct will know if im in canda or the us,
also have my friend plug his phone line in only, and keep ours out .
if i have a problem when its activated in canada i can always bring it back across the border, we only live 15 minutes apart
thanks again
Username: Lklives
Post Number: 16089
Gocuse..U read it properly....yes the receivers , once installed at your house in Canada, can be activated by your bud in the US...I do suggest U stay on a phone (like a cell phone) with him, when HE calls DTV for activation...DTV will ask a HIM a few questions such as "is channel 200, 201, 252 (examples) working now?", which he won't know the answer to, unless the 2 of U are in communication with each other....DTV will want him to use his US house phone for the activation call, and remember that U cannot call DTV yourself from Canada for activation..but yes U can have the receivers installed and in place in Canada, WHEN he does call..
BTW...U may/prolly will get the same local channels as your bud in the US, if U are only 15 minutes apart...
and again, NO phone lines plugged in for U, but its OK for your US bud, the account owner..
DTV will NOT ever know your location, UNLESS U plug in the phone line to a receiver ( many ppl will cut or remove any phone lines near the receiver, just in case the wife or kids "accidentally" plug it in)...or somebody rats on ya...BTW, there are no "sniffers" driving around in trucks looking for illegally used satellite receivers, contrary to a sometimes popular myth...nothing can detect a satellite receiver, other than a phone line..
Username: Nydas
Post Number: 18268
Your needs are based on wanting to have good TV and not particularly on the cost of it.
I suggest you study what Satellite-Products are available at sadoun.com.
Depending upon the type of receivers, you should look at the three alternatives for installation. The two prices I have mentioned, are for LNBF alone or with Dish as well.
Look at he specs and talk it owver with your friends in USA.
This is a new dish from DIRECTV with three LNBs to receive 101°, 110°, 119° - $50 or $100. In addition you will be able to receive the new Ka satellites at 99° and 103°. Watch all local and National HDTV channels offered by DirecTV.
This is a new dish from DIRECTV with three LNBs - $85 or $120 - to receive 99°, 101°, 103° satellites.
This is a new dish from DIRECTV with 5 LNBs to receive 101°, 110°, 119° satellites. - $98 or $130 In addition you will be able to receive the new Ka satellites at 99° and 103° for local HD programming.
Installation would be extra. You may use the current Dish but I would encourage you not ot use the BEV or DN LNBFs. If you buy from ebay, buy something very cheap advertised for DTV, but, on the whole I would suggest you avoid buying on e-bay and get it via your friends in USA or directly from a reputable seller like Sadoun.
Username: Lklives
Post Number: 16090
Numb Nuts (NN) said "Your needs are based on wanting to have good TV and not particularly on the cost of it."
OBVIOUSLY..the man is wanting guaranteed TV based on price costs, thats why he's sub SHARING.!!!...are U really that STUPID NN?.... he doesn't have to pay the entire bill himself, and will have guaranteed TV with SUB SHARING ...FTA is basically down and not dependendable nor safe when using IKS and NOT free when ya consider the costs of receivers, and the risk factors with IKS...so NN, your remarks are stupid, and off the subject of his question regarding this thread , WHERE DO I GO TO ACTIVATE THE DTV RECEIVER?......
Username: Gocuse3
Post Number: 56
thanks again
all my questions where answered
its good to have this forum to come to for answers
Username: Lklives
Post Number: 16092
BTW...Gocuse...U will ONLY get the same package and channels as your bud in the US...U can NOT get more channels than him, by adding a different dish with more LNB's aimed at more satellites..and most DN or Bev dishes are fine to use if a circular LNB is aimed at the 101W sat...I know hundreds of ppl who use DN and Bev dishes all the time for Directv..many ppl have switched back and forth from DTV and DN, using the same dish... most of the DTV channels, they are on the 101W sateliite, so U will be all set...if your bud has HD channels and HD receivers, U will require other LNB's on the dish, and the HD receivers too....
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 527
Gouse. Listen to LK, he has been at this when NN was just a gleam in his old man's eye, if ya get what I mean.
He is the man, period. NN is a wanna be.
Username: Nydas
Post Number: 18278
Gocuse: I am glad you got the answers.
Username: Harding
Post Number: 82
Username: Gocuse3
Post Number: 57
thanks again
looking at getting the hd dish and lnb's
once you go hd theres never going back
Username: Lklives
Post Number: 16096
funny ya say that...cause some of my homes have HD, some don't..and not having HD, don't bother me...I only miss HD during football season and sports..
remember yer bud in the US must have the HD package or U can't get HD...and U will need a HD receiver too..as well as the DTV slim 5 lnb dish..and that dish ain't real simple for the novice to align, but an experienced guy can install it in 10 minutes..
Username: Nydas
Post Number: 18285
Gocuse: Everything is going to be HD very soon. If you budget for it and stay with HD, you will enjoy TV far better.
Username: Lklives
Post Number: 16101
HD DTV Receivers for as low as $99
Username: Nydas
Post Number: 18287
LK forgot to check the conditions. This is just one of the conditions in the USA..
"Prices shown are "lease upgrade fees." Additional $4.99/mo. lease fee applies for each DIRECTV Receiver you add. Programming commitment required. See terms."
Username: Lklives
Post Number: 16103
Didn't forget anything..I saw that...the HD DTV receiver is $99
Username: Gocuse3
Post Number: 58
you have to love hd sports
thats why im getting direct with my friend
theres only so much curling you can watch
Username: Lklives
Post Number: 16109
Suggestion....the more friends , the cheaper everybodys monthly cost...DTV is also VERY lenient with the amount of receivers allowed...its ONLY $5 an additional receiver each month, after the first one which is free....get as many as ya can, and share em with family and friends...I know someone with 18 on their account, but thats NOT normal...but having 8-9 is not that uncommon..many ppl have large houses, and like TV in their garages, basements, 4 bedrooms, kitchen, den, and living room... and remember, shared subsrciptions will work anyplace in US and Canada, Mexico too....just have the roof antenna/dish and yer good to go...
Username: Harding
Post Number: 85
So I suppose I can charge my friends accros the border $15 per month and make a profit?
Username: Gocuse3
Post Number: 59
hey lk
was looking at getting 6 and splitting the cost 6 ways
maybe after i get it going i would add acouple of more
thanks again
Username: Pancho_vili
Post Number: 39
He most own a Motel
Username: Gocuse3
Post Number: 60
sorry
i have one more question
is it possible to get direct tv with a po box number for you raddress
thanks
Username: Hannity
MAYBE I CAN ASK TO, ADM FOR BAN YOU
Post Number: 257
I am in Canada I sub to Directv. I have 8 receivers in my name, I have them farmed out to 4 people, we get The works for 115 bucks a month divided by 4.
I use all the same dishes and LNB`s I used for FTA on DN.
Our only problem is we have A texas address so do not get locals, so we get locals on Shaw Star Choice with basic package (also shared)
Was not easy getting hooked up, because of phone issues, could not use Magic Jack because no high speed in our remote area, only dial up.
Finally got hooked up via email, they kept asking me to phone the 800 number, but could not because it does not work in Canada unless you have Magic Jack etc. About a dozen emails and they finally hooked us up, I just kept saying I was on the road cant get to a phone, only have my laptop etc, finally someone flipped the switch.
Account is in my name at DTV, I manage the account on line now, paperless billing. Directv takes the amount off my Canuck Visa every 15th of month, the others send me checks.
Magic Jack would have made it so easy, but like I say no high spped in my remote northern area.
If you can get them hit from the US might be better, we had a few days of re hits before all 8 would work. Once on line you can send your own refresh hits.
We had to buy the 8 receivers off ebay. Look for good buys with brand new equipment, we got ours for 79 bucks each with never used cards.
Being an owner of the boxes means you dont get the 3 month special. But like I said we went with the premium so we get all but PPV and adult, dont want the adult anyway
Username: Hannity
Post Number: 258
You can just make up an address and then immediately sign up for paperless billing, make sure address has Zip code that makes sense to the address you give. And you want locals, so dont be dummy like me and get a address too far away to receive locals.
Great if you have a friend that lives in States, but you can make up address in detroit or Buffalo if you are in Ontario, switch to paperless billing at dtv.com the moment you have an account.
Magic Jack is the way to go, if you have no friend in States.
Username: Lklives
Post Number: 16111
NO..U cannot use a PO box..and must use a legit US address and phone number when subscribing..
Username: Ei_toro_the_great
Post Number: 62
RUSH, you have no idea what you are saying.
please don't mislead the people that come here for help.
Your phone number Land or Air needs to match
the address you give them.
I always thought the Italians were smart people.
Username: Harding
Post Number: 90
Rush: You contradicted the great Godess LK.
To the fun bunch, you are now a prey. They will hound you incessantly. Whiskey is just one of the stooges.
Username: Lklives
Post Number: 16112
Again I know U cannot use a PO box address or make one up, and do need a legit phone number too...
I have heard a few VERY rare cases, where DTV will accept cell phone numbers, but I have never heard of anyone using a Magic jack (MJ) phone number...the Magic Jack issue is a good question cause many ppl like myself have a magic jack phone as a 2nd or only main land line..MJ numbers are not published or listed anyplace that I know of, so I really dunno how/if DTV would accept it...I believe they would, but not sure...but a legit US address is definitely required, no "made up" adresses are accepted...and if ya have an MJ phone at a legit address, I guess DTV would accept it....
we're kinda getting off track here, but the MJ thing is a very good question
ya know the MJ requires a high speed internet connection..and if ya use Verizon DSL, they assign your internet account a phone number, but yer MJ is a completely different phone number assigned to ya by the MJ ppl....but now I don't see how yer receiver would ever have the MJ number unless ya put a 2 line coupler from the MJ, 1 into yer phone handset and the other to yer receiver....cause the main thing about the phone is that DTV wants it plugged into the receiver always...so again, I'm not sure how the MJ would work or be accepted...like I said I do know a VERY few rare cases where ppl have been allowed to use a cell phone, cause they have no other phones..interesting thing about this MJ....not sure if we'd ever know the answer, unless someone actually called DTV and asked them straight out about the MJ thing....now I'm curious..lol
Post Number: 66
DirecTV: Customer Agreement
f) Phone Connections. For optimal performance of your Receiving Equipment, including ordering with your remote control or receiving certain Services, each of your receivers must be directly connected to the same land-based telephone line. If you add Service on additional TVs, you may purchase a separate subscription for each additional TV, or, if all your receivers are continuously connected to the same land-based telephone line, we can "mirror" programming to your additional TVs and charge you only the fee amount described in Section 2. You agree to provide true and accurate information about the location of your receivers. If we detect that any receiver is not regularly connected to a land-based telephone line, we may investigate and, if it is determined that the receiver is not at the location identified on your account, we may disconnect the receiver or charge you the full programming subscription price for the receiver.
Username: Harding
Post Number: 92
I wrned you what will heppen.
Post Number: 67
LK......I do know few rare cases where ppl have allowed to use a cell phone
Why not, DirecTV provides Service where
land-based telephone line is not possible.
(g) Mobile Units. We provide Service to Receiving Equipment installed in mobile units such as campers, boats and other recreational vehicles. However, this Receiving Equipment is not eligible for the additional TV authorization discount described in Section 1(f).
Username: Lklives
Post Number: 16113
I was refering to HOME based receivers for new subscribers with the free installation...DTV has allowed a few ppl I know to use their cell phones, because they have no land based home phones....DTV is very lenient in most cases, depending on the rep ya speak to...more interesting to me is the "magic jack" issue...
Regarding DTV's threat to disconnect and investigate ppl with no phone lines plugged in, thats just an idle threat...I have NEVER heard of 1 person losing a subscription or a receiver because the phone line is NOT plugged in...I know HUNDREDS with no phone line plugged in, and for many years!...I even know a few, who have been "investigated, had their service disconnected, had 15-18 receivers, no phone lines, and got their service back and all their receivers reactivated, with just a simple BS explanation to DTV..."I have a very large house and no land lines"..and DTV even sent them a URL with an aerial pic of their "large house" , questioning the number of receivers...so my point is, DTV doesn't really follow through on their threats or agreements even when they have pics, and have ya...again, they are fairly lenient about most things...except the need for a legit US address and phone number (not necessarily plugged in)..
Username: Lklives
Post Number: 16115
FUKKK OFF Numb Nuts...stay out of my business.... worry about yerself...go read and learn something for a change....U don't even know WTF we're talking about, so STFU...
Username: Lklives
Post Number: 16116
Numnb Nuts...go do a SCAN of DTV receivers that U have witnessed yourself personally.....and make sure ya don't use DN LNB's......ROTFLMFAO...yer fukkn clueless!!!....
Nalin Nyda
Username: Nydas
Post Number: 18260
Posted on Wednesday, February 24, 2010 - 04:20 pm:
If you have the right LNBs (DTV LNBs are different from DN LNBs) you can scan in Canada. You are confusing receivers and LNBs. The receiver will be bought or obtained somehow in USA. It can be and usually has to be rescanned after it arrives in Canada. I have seen all the things I am talking about.
Username: Nydas
Post Number: 18324
LK: Rush said it all in great detail and was very precise about how to avoid the contact probleems.
You are saying this one time and that another time and unnecessarily turning a striaghtforward talk into a debate.
Q. E. D.
Post Number: 49
RUSH jokes too much
RUSH
Username: Hannity
BAN YOU
Post Number: 137
Posted on Monday, October 12, 2009 - 03:52 pm:
Yes Justforhaha you are right about the luck of the draw who you talk to at DTV. Imagine only being able to communicate via email with them...lol
Most things I can do now at the DTV web site, but I had a neighbor that wanted a strange international package, think it was Mexican, lol Esvaldo
Seriously a international package, and they refused to do it, kept saying phone us at this number. I would say, I am on the road for a month with my laptop cant get to a phone, they would not do it.
Finally I emailed saying I phoned and I still cant get it whats the problem, finally a girl activated the rare international package via email.
Magic Jack is the answer for that, if you are out of the country, but I do not have high speed.
Having Thanksgiving with the Chavez family today.
RUSH
Username: Hannity
BAN YOU
Post Number: 138
Posted on Tuesday, October 13, 2009 - 11:23 am:
love the Mexican hat
Ya Magic Jack I hear is great, if you have high speed internet, I live in the deep woods. And it wont work with sat internet even I am told
Username: Lklives
Post Number: 16117
Numb Nuts...go email DTV and give em a phony US address, tell em U have absolutely NO phone number, and then come back and tell us U got a new DTV subscription.........ROTFLMAO...what a bonehead!........go play with yer old Fortecs and tell us how ya got N3 hacked too, and how ya got IKS on yer Pansat 2300 working also!...
Username: Nydas
Post Number: 18327
LK: Hombre has just admitted that you are/were justforhahas.
Username: Lklives
Post Number: 16118
Numb Nuts (NN)...we all have heard about YOUR idiocity...your stupidity is legendary!....
Username: Nydas
Post Number: 18329
LK: Go and try other forums. Hombre has just admitted that you are/were justforhahas. You and you people are deliberately coming to this forum under different IDs and posting irrelevant and wrong ionfo.
I am busy watching details of Hawai tsunami, and have not time to bother baout your idiocy. Have you heard about that?
Terhan, Iran Iran
Post Number: 538
What's a baout?
Username: Lklives
Post Number: 16121
Username: Gocuse3
Post Number: 61
lk
i have another ?
can you sub share bell , if so can you set it up the same way as dirct, have you rfriend call get the receivers plug his into a phone line and get all the others out then activate the receivers from all the home they are at
thanks
Username: Lklives
Post Number: 16151
yep Gocuse...Bev/Bell and DTV work the exact same ways..
Username: Lklives
Post Number: 16157
Fukkk off Numb Nuts...U have no clue again!
Username: Lklives
Post Number: 16159
I never wavered or changed my postion..and never said anything wrong about this....U need to STFU...learn English ..and get the fukkk out of here cause NOBODY likes ya or wants ya here!
U post nonsense just to get yer post count up, and try and start shi*t...
Username: Nydas
Post Number: 18379
LK; Good that you admitted that a land line phone is not needed. Now start looking at Rush'e pst and see where else you were wrong.
You know you have changed your postion and you have more changes to make in your statement to come close to Rush's statement, because
RUSH IS NOT LYING and
YOUR ARE JUST GUESSING
Username: Yakkydoodle
Post Number: 45
please! don't forget nylon's a liar too!
Username: Nydas
Post Number: 18381
J-Tag: Excuse me. What games? I don't play games with pictures and I don't beleieve in your kind of profanity.
Post Number: 114
Nalin Nyda...............RUSH IS NOT LYING and
Now Nalin let us look it this way, if RUSH lives as he had said
deep in the woods of Canada where DirecTv is not licenses
to do business in Canada and Lk as you have said lives in the USA
now who do you think the people believe RUSH or LK?
Username: Nydas
Post Number: 18383
Whiskeys:
The first line in this thread - the posters concerns.
"I'm looking at getting direct tv, my friend live's in the states and im in canada"
Your statement.
"Now Nalin let us look it this way, if RUSH lives as he had said deep in the woods of Canada "
I would expect Rcuah to know more about DTV subs in Canada. Then when Rush says he has had DTV installed in Canada, I have a right to believe him,
because LK could not have had DTV installed in Canada.
Q. E. D.
Post Number: 115
Hey good too see you boys again.
Username: Lklives
Post Number: 16165
and if ya believe NN...she witnessed first hand ppl doing scans of DTV receivers!....
Username: Lklives
Post Number: 16166
and me and Rush agree on everything, except his saying to "make up any US address", which I know ya can't do...and stated...
Username: Nydas
Post Number: 18385
L.K: You are getting there. It is you who has been posting continuously. rush only posted once or twice. So I am glad YOU are agreeing with whatt Rush said.
So you agree that
"RUSH IS NOT LYING"
Q.E.D.
