I need a cooling fan.. how do I make one?
Username: Delirium
Post Number: 11
Hello, I need a cooling fan for my cabinet to keep my receiver cooler. I went to radio shack, but they dont sell AC fans that have the plug on it already. I dont know how to connect a plug, can anyone help?
Would it be easier to connect a computer fan? The problem with that is that those are DC right? Help!
J. Vigne
The fans they sell at R.S. have only two wires, you simply connect one wire each to the inside of a two pin AC plug. Someone at the electrical supply shop or the hardware store where you buy the plug should be able to show you how to hook it up. Place the fan so it draws air through the amp instead of blowing air into the amp.
