Build log -- mauricio & charles pg. 2 **PICS**
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5322
For some reason my older thread was taking a while to load (maybe because of 77 posts) so i figured I would just create a new thread with the updated pics. I didn't take pics of the plexi box with the zinc-plated screws in plexi because it started raining again. I updated a couple more pics on my earlier thread a couple days ago if you didnt check it out:
https://www.ecoustics.com/electronics/forum/car-audio/612573.html
Give me a min to upload the pics.
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 258
i don't have a minute. lol j/p
Username: Dustin3
Post Number: 5323
Username: Dustin3
Post Number: 5324
Username: Dustin3
Post Number: 5325
Post Number: 259
Damn. those are nice. i like your balancing skills on the chairs lol
That plexi looks awesome. good job and nice build log. mad props
Username: Dustin3
Post Number: 5326
Thanks Smith, I will be having a website soon as well :D possibly www.DLdesignz.com :D
Username: Gcs8
Atlanta, Ga
Post Number: 256
cant even tell how the plexi is held on, i cant wait to try and cram my box in my trunk.
Username: Dustin3
Post Number: 5327
The plexi in the picture is just sitting in the groove, not being held in by anything. It fits nice and snug though :-)
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 215
Nice work man! I wish i was that talented.
Username: Dustin3
Post Number: 5328
Thanks
Diamond Member
Www.stainles... .ecrater.com
Post Number: 22088
Looks good man. I like the plexi. It makes a difference!!
Username: Dustin3
Post Number: 5329
Thanks Paul, the plexi does make a nice touch to the enclosure :D
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15962
looking very good man
hey how thick is that plexi - hope it doesnt flex since it seems to be a sizable piece
psp port FTW - those just seems to have majic in them since they produce some sweet bass & good numbers on the meter too ...
Username: Dustin3
Post Number: 5330
It's 3/4" Rovin :-) There is not gonna be any problem with flex. I think i could have gotten away with 1/2" as well and still would have been okay.
Thanks Rov!
Username: Rovin
Post Number: 15963
wow 3\4" must have been expensive but yes it shud be sturdy enough ...
Username: Dustin3
Post Number: 5331
I can get plexi for very decent prices :D For all of those who were wondering
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 230
^email replied
Username: Dustin3
Post Number: 5350
I didnt get one from you?.. can you send another one? I can start working on your order today..
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 4301
extremely nice lookin' enclosure
Username: Dustin3
Post Number: 5351
Thanks mark. These are the final pics. I havent gotten ahold of mauricio for a while so I'm not sure when im shipping it out. Let me know what you think :-)
Username: Dustin3
Post Number: 5352
Here are some when in their in some different lighting
Username: Mendonmafia
Post Number: 1959
should have carpeted the inside of the one with the plexi, that would look tight.
Username: Ducka
Shelby Twp., MI United States
Post Number: 1360
^ or at least painted it... Still looks good, Personally I would have done something with the inside.
Username: Dustin3
Post Number: 5354
Yea, i was thinking that. But the sub magnets will be the only thing showing through the plexi anyway. But ill keep that in mind for the next time :-)
Username: Dustin3
Post Number: 5355
But to be honest, i kind of like the look of being able to see whats on the inside
Username: Insearchofbass
York, Pennsylvania
Post Number: 13496
A neon in there might look cool with a painted surface inside
York, Pennsylvania
Post Number: 13497
Bassman how much would an .75 all plexi box cost me for my idmax 12 1.42 cubic feet gross sealed
Username: Dustin3
Post Number: 5356
Any reason why your wanting all plexi? I have not done, nor read alot, about all plexi boxes. I know that one plexi enclosure fabricator (forgot the name) used some type of melting technique to melt the two pieces together. I am not sure what he uses though. I could do some research and get back to you.
Post Number: 1961
the only problem with plexi is you need to use cleats to attach it. drilling into the side is very difficult with plexi unless to have special bits and if you tap all the holes. You could use all glue and clamps but then you need clamps and need to put something between the clamp and the plexi to keep from scratching it.
York, Pennsylvania
Post Number: 13498
just thought it would look cool and thought maybe you could do it. really id like to get an idea what it would cost roughly before I have you do all that research. If it costs to much or is too difficult i might settle for something less demanding
Username: Dustin3
Post Number: 5357
3/4" plexi get pretty high in price pretty quickly sean. For example, the plexi i used in these pictures was 15" wide and 6" tall and it cost $45... so it is expensive to do. I could help you work out something as little less dramatic if you want?
York, Pennsylvania
Post Number: 13501
wow yeah a little too expensive for me....what ideas do you have
Username: Dustin3
Post Number: 5358
what are you looking to do? there are many different window combo's + paint or carpet combos that you can do to really set off the enclosure as far as looks go.
York, Pennsylvania
Post Number: 13502
I was thinking maybe a sealed box with a window painted inside with a neon to set it off like what I said above....maybe even idmax painted on the inside
Username: Dustin3
Post Number: 5361
I have some connections with some cnc machinests who can do custom engraving in plexi -- if you were thinking of engraving IDMAX in some fancy lettering of some sort? with some led's on the bottom and upper corners of the front baffle of the box to light it up?
That might look pretty cool..
York, Pennsylvania
Post Number: 13504
That sounds cool but what would something like that cost me?
Username: Dustin3
Post Number: 5362
Box would be priced out like this (rough estimate):
Box alone = $80 + shipping
3/4" plexi for a window $40
Custom engraving = I would have to call around some places and see what I can do for that.
So your looking at $120 + engraving price + shipping (which would not be much for this small of box)
How does that sound?
York, Pennsylvania
Post Number: 13505
when you get the price for the engraving let me know...as far as shipping im in the 17404 zip what do you think that would cost
Username: Whatmh5
Post Number: 24
You seem to do some great work.
I'm glad your building my box!
Username: Dustin3
Post Number: 5363
Sean,
Shipping would be around $35-$40
York, Pennsylvania
Post Number: 13506
all right all we need now is the engraving costs
Username: Dustin3
Post Number: 5364
I will get back to you Sean
York, Pennsylvania
Post Number: 13511
ok thanks man
Username: Loc_out
SoCal
Post Number: 3086
Bassman3 nice work. Is the second box a 15 or 12? what is it tune to?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 232
"You seem to do some great work.
I'm glad your building my box!"
Me too!
Username: Dustin3
Post Number: 5366
Thanks Lowlife,
The second box is for the new FI Q 15". It's tuned to 33hz with 2 4" aero's.
Username: Dustin3
Post Number: 5367
haha yea, Sean. Your box is going to be nice. I replied to your email btw
