Mid-Bass Drivers for Honda Civic Hatchback
Username: Extremetech
Malta
Hi,
I require a set of Mid Bass drivers for my system (Rear speakers). My current system includes -
Front
Infinity Kappa Perfect 6.1
Orion Xtreme XTR 500.2
Rear
Image Dynamics IDMAX12 V3 D4
Boss PD-4000
I need a set of Mid Bass Drivers Max 125RMS
Thanks
Malta
Head unit - Pioneer DEH-P780MP
Equilizer - AudioControl EQL
I am searching for a set of good midbass drivers which aren't very expensive but work out well as rear fill. They will be installed on the orion X-treme XTR 500.2. 125w RMS x 2. (6" to 8")
Considering -
Image Dynamics
Kicker
CDT
Eminence
Found Eminence Alpha-6C 6" - 100RMS
What do you think about these ?
Malta
any help
Malta
I found a set of Kicker RMB6
125Wrms
Are they good for my rear fill ?
Malta
Are they any good ?
Username: Tgspeedracer
Denver, Co Usa
Post Number: 23
I had a hatchback a few years ago and ran jl coaxles and thay had great mid bass. I would just goto a local shop and listen to some diff speakers
Username: Nick_belsky
North Canton, Ohio USA
Post Number: 106
There are a thousand mids out there that can fall into that description, like Tyler said, go to a local shop and give some a listen. You may find Coaxils will work better for fill anyways.
Malta
Post Number: 7
What on earth are you answering.. is this forum the same as it was 2 years ago ??? Coaxils for rear fill ?? You really want me to have distortion @ the back of my car.. what kind of guidlines are these ? i just need two mid woofers thats all im asking.. is it to difficult ?
