Pioneer
Username: Esms06
Everett, Wa U.S
Having trouble wiring my Pioneer deh-p5901b. Cannot find wiring diagram because I bought it used. I just matched up the color wiring and for some reason when I tried it it didn't work. It turns on and powers on but no sound to the speakers. First time trying to install a unit. I have three extra wires left. one is for the amp, power antenna, and dimmer. the hyundai didn't have the wires for it. your help is greatly appreciated. Thanks
Username: Regrooster
Post Number: 3213
If you can use a multi-meter then take a look here and it might give you the answer
http://www.tehnomagazin.com/Auto-radio-car-connector/PIONEER-Car-Radio-Wiring-Co nnector.htm
Username: Esms06
Everett, Wa U.S
I'll try that tommorow oh as for the wiring the ones i have left over is the amp turn on (blue/white), power antenna (blue) and dimmer (orange/white)
Username: Esms06
Everett, Wa U.S
I tried the link but it didn't work.
Username: Esms06
Everett, Wa U.S
any other suggestions? i'm stumped
Post Number: 3312
Select from this list
