This sub vs. that sub
Username: Kyle_lowe
Post Number: 962
Here is another one of these threads.
hopefully there is someone with experience with both subs
The two options I have right now are either a RE SE, the old model, not the new x model, or a SA 12
both are 12" d4 to be ran at 2 ohms
the box will be 1.5 cubes tuned to 34 hz
im just looking for an opinion on overall quality and which one you think has the potential to get louder
any help is appreciated
thanks
Username: Kyle_lowe
Post Number: 963
no opinions on this?
well i think i am going to go with the sundown sa12 unless anyone knows of any problems that this woofer typically has that could make me not want to get it
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16049
havent heard the SA12 so i cant say
but have worked with the SE & if all the space u have is for 1.5cuft ported u shud not be using a 12" ...the 10" wud be better suited for that amt of cuft ...
Username: Kyle_lowe
Post Number: 964
the websites for both of these woofers call for a slightly higher tuning if the box is going to be that size.
that plus i will be buying used and i do not have the option of getting a 10"
thanks for your help, i really appreciate it
Username: Mendonmafia
Post Number: 1992
so tune it to 36 then. the box volume is more critical to the performance anyways.
Username: Kyle_lowe
Post Number: 965
thanks mark
i just talked her into giving up more trunk space so i will be able to build to the sundown recomendations
