Bronze Member Username: Mailbox4youPost Number: 35 Registered: Dec-07 | C/P Testing of a full release is now underway for Kbox! Also you may see a surprise tonight on Kbox!!! |
Silver Member Username: KboxPost Number: 107 Registered: Jul-09 | I'd suggest a wait and see what get's posted but don't expect to see any 3rd party posts on the Official website and anything else is up to you. Being skeptical isn't always a bad thing so long as it's controlled with a little bit of optomism. Being wise doesn't gravitate anyone from being stupid or naive....visa-versa |
Bronze Member Username: James_millardPost Number: 25 Registered: Jan-10 | Oh Rly ? Normally its the other way around..... the Traditional "Super Bowl Blackout".... |
Platinum Member Username: PlymouthCanada Post Number: 12718 Registered: Jan-08 | Super Bowl is always available Free to Air on Feed! |
Silver Member Username: KboxPost Number: 108 Registered: Jul-09 | yes always available Free to Air |
Bronze Member Username: EkoneunoPost Number: 56 Registered: Nov-06 | Does anyone know which channel on Kbox will have the superbowl? None of the CBS are working yet? Thanks |
Bronze Member Username: Pirate_pete_208Post Number: 17 Registered: Jan-10 | Ekoneuno, if you live near a Walmart, Kmart or Radio Shack try one of them to see if they have a good set of Rabbit ears to bring in CBS in your area???? you other choice will be to move your Dish to a FTA Satellite that will carry the Super Bowl, that is if your Dish is large enough and have a Linear LNB your last choice, buy a case of beer, good bottle of wine and head over to a friend's house. |
Silver Member Username: AsploverPost Number: 261 Registered: Jun-06 | So far there's isn't any new file. Lets see when it comes |
Silver Member Username: Pannu16Post Number: 917 Registered: May-06 | Yo MC Fta industry nothing is 100%.. dont give guarantees next time!! |
Bronze Member Username: Mailbox4youPost Number: 37 Registered: Dec-07 | Pannu ... and all K BOX is Back with almost all channels ..... |
Bronze Member Username: AbusubhanPost Number: 48 Registered: Sep-07 | What about PPV channels? Will they be up as well? Thanks in Advance |
Platinum Member Username: NydasPost Number: 17922 Registered: Jun-06 | URLs to all the IKS is here. |
Silver Member Username: AsploverPost Number: 263 Registered: Jun-06 | so far, PPV's are still not there. It seems K BOX is not keen on PPV right now |
Bronze Member Username: BhardwajMississauga, Ontario Canada Post Number: 52 Registered: Aug-07 | can i get a list of channels working on kox thanks. |
Platinum Member Username: NydasPost Number: 18183 Registered: Jun-06 | There are at list two adult channels woking on kbox, but no PPV. |
Silver Member Username: HardwarecrazyPost Number: 181 Registered: Dec-07 | Plymouth, where are you? STFU this cumhead once and for all. |
New member Username: Pansat2500aaPost Number: 2 Registered: Feb-10 | how about bangla channels |
Silver Member Username: GrnncPost Number: 140 Registered: Apr-08 | They are working...804,805,806,818 |
