2 Kicker Solo-Baric Subs, But what amp would do?
Username: Tylermoncrief
Post Number: 15
Okay peoples im back. I sold all the old stuff I had and thought smart
Okay, I just got these kickers that were on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18804&item=5706700349&rd= 1
750 RMS 1500 PEAK. I got 2 of them
So 1500 RMS 3000 PEAK. What amp should I get to get the maximum power of what I want.
Im sure the CD\DVD\MP3\XM Head Unit is good.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39752&item=5706141079&rd= 1
You guys told me not to go with the Legacy and Pyramid stuff. I also have a in dash motorized screen. Not hooked up yet!
But what AMP would be best at a suitable price. Nothin over $350. I got 350 left. Should I get 2 amps for each sub. I seen a legacy 1600 Amp. Since I read in another post. It can say 1600 but doesnt give you 1600 Watts. So I was thinking of gettin 2. So tell me what I should buy, or should I get 2.....
Just give me help
Username: Jonathan_f
GA USA
Post Number: 594
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5706677594&rd= 1&ssPageName=WDVW
Solid, solid amp. One of the best you'll find. Orion makes some of the best amps out there. And it's under your budget. Awesome deal, too, I might add.
Post Number: 16
Anyone else got any suggestions on the amp I should get?
Username: Davids2004
Houston, TX USA
Post Number: 182
Since your subs are dvc 4 ohm wiring them together in parallel will give you a 1 ohm load. I would use this amp and it will give you 1500 watts rms at 2 ohms which will give you 750 rms per sub.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5706762656&rd= 1&ssPageName=WDVW
These are also a very solid amp too and will be about 40.00 cheaper.
Houston, TX USA
Post Number: 183
Plus the hifonics amp has many more features then the orion amp. Also the hifonics comes with a remote bass control knob which will allow you to turn the bass boost up and down from the front seat which is a cool option.
Username: Deadman
Kirksville, MO USA
Post Number: 19
Davids, your previous post says the BX will give you 1500 watts at 2 ohms. The BX will supposidly give you 1500 at 1 ohm which he would like. I would go with the orion though dude. Orion makes great stuff, Hifonics are questionable.
I have 2 12" 04 L7's in a ported box 5.0 cubic feet tuned to 40 htz and am running my rockford BD1001 amp at 1 ohm. It slams like no tomorrow and the amp never gets hot. Even though it's only supposed to be stable at 2 ohms.
