Unregistered guest |
Posted on What is the difference between an optical or coaxial digital audio in/out connection? Is there any difference in quality? Thanks!
Silver Member Username: Project6
Post Number: 941 Registered: Dec-03
Posted on a lot of debate on which is better, but it boils down to one thing, which one do you prefer. No definitive answer just arguments. Optical uses light pulses to transmit information, and the other is digital signal through wires, longer (>25 ft) runs seem to affect signal. |
George Tench Unregistered guest |
Posted on Thank for the info. Berney! I appreciate the quick response. |
