Help with wiring crap
Username: O0airjordan120o
Post Number: 432
i have a 1994 ford e-150. im installing a new system. i was hoping my other wireharness would work... it doesnt. do they make a head unit wire harness for the 94 e150? can i just wire that sh!t up myself? or am i sol??
Username: Van_man
Boston South, MA
Post Number: 5228
try cruthfield. they carry alot of after market harnesses.
Also, you could go old school hard wired, but try to get a wiring diagram of the stock if you can to help.
Im sure they make a harness, Ebay is good for stuff like that as well.
Username: Gcs8
Atlanta, Ga
Post Number: 323
could look hear http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Ford.html
or google around but wiring harness is easer, or you can hunt down the wires you need and cap off the ones you dont, say you only need the power the switched and the ground wires and every thing else goes throw the rca's to the amp then you only need to find 3 wires.
