Viewsat question..
Username: Cyberx
Post Number: 49
OK suppose there is a v-link or weather forcaster.. If one was crazy enough to use it, is it worth purchasing an HD Viewsat.. Will they work since there are only mpeg-2?
Thanx in Advance
Username: Nydas
Post Number: 18272
I think it would still work in SD mode. But till the dongles come out and some people test them, it is difficult ot predict.
Username: Perycles2005
Post Number: 141
B davis...one thing is for sure it will work with the regular Viewsat...if you have it...don't buy yet the HD...wait until some one post some results....
Username: Oleg1474
GRU, CCCP RUSSIA
Post Number: 1423
Att !! ; ViewSat/PanSat :now working on BiNs prog(euro/ecm666)wide open,only temp. fix
Username: Runnerguy
Pluto
Post Number: 2066
Att!!! Gratsi Gratsi.....I plug in VS 2000 and Big Wide Open P@rn looks to be in HD or dat just mi eyes. Olegie amaze again. Temp is OK Olegie...we fix later. euro/ecm666 bin download OK
Username: Billybobo
Post Number: 12
Where do I get that file, (Euro/Ecm666) Thanks
Username: Danoh
Post Number: 141
will this work 4 a vs platnium?????????just wondering and waiting 4 nfusion
Username: Cyberx
Post Number: 50
ok there is no standalone bin.. That we are all smart enough to know I would think.. Back to the original question, will any Viewsat HD boxes work in HD? I dont believe any are mpeg 4.. Is all HD now mpeg 4?
Thanx
Username: Shenanigans
Post Number: 333
The Euro/Ecm666 file Dr. Oleg recommends is only available on his home plant Uranus. He doesn't understand that our internet won't reach there. Hopefully the next time he visits home, he will think of us here on Earth and bring a copy back to share. :-)
Username: Plymouth
Post Number: 12890
Username: Kirok
Hooterville, Ontario Canada
Post Number: 33
I own a VS HD, and it is MPEG4 compatible.
