Coolsat 4000 pro has freeze up on me
Username: Taxi_guy
I no longer have control of my box. Do I need to re-install some kind of file or do I have to wipe the box and re-install?
Username: Nydas
Post Number: 17966
Coolsat 4000 pro or Coolsat 5000?
As far as I know Coolsat 4000 works fine on strictly FTA channels.
Username: Chaff
Post Number: 19
I'm not sure if this helps
Coolsat 4000 Quick DataBase Reset - NVRAM CLEAR
All thanks to bega for this post
The quick way to do a factory reset on any Coolsat (or Cooltec for that matter) is to turn the receiver off with the remote, then go to the receiver and hold the channel up button and press the power button, then release both. From here a diagnostic screen will pop up. Go to the far right and almost to the bottom and you will see "NVRAM CLEAR". Select that box and hit OK on the remote. Turn the receiver off again with the remote and then on again. VOILA, back to factory defaults (ALL Except for the firmware you have loaded is reset. Be sure to know your dish settings and backup your channel list if you don't want to loose it before doing this)
FYI: Also, if you EVER lose your password on a Coolsat, this is also where you can go to find it out. You will see the password box just above the NVRAM CLEAR. Select the password box and press ok and it will briefly show you the password
or this
application/mswordUpload
Jtag the Coolsat.doc (4.5 k)
