Audiobahn
is it really that bad if you just want to have diecent sound and aren't going to be in any competitions and it is just for your own enjoyment
Username: Davids2004
Houston, TX USA
Post Number: 186
I would say yea but most will say no. I would say its decent equipment but not near the best but for your enjoyment it will do.
Username: Disturbedpriest
My friend has two 12" audibahns, I would recommend some of those adire products i keep hearing about.
Username: Jonathan_f
GA USA
Post Number: 622
It's pretty bad. It's not the sound quality (although it is very poor) as much as it is the durability. They don't last, they're made from poor components. But of course if it makes you happy, go for it, because we're not the ones that listen to it everyday.
Username: Pat_l
Tucson, AZ USA
Post Number: 331
You can buy it but you wont enjoy it and thats what car audio is for- too enjoy
