Wiring up the sub
Username: Thefluke
Hi all,
I just purchased a sony Explod bass box (http://products.sony.co.uk/productdetail.asp?id=3_30_1848) but I'm not sure of the best way to wire it up.
I already have an amp powering the front and rear speakers. I don't have a "sub out" on my head unit so I'm not sure of the best way to connect it up to the head unit.
Also, on the power front what can I do for power? Can I split the existing power cable or do i have to run another cable?
How would you people do it?
Any help would be great.
The Fluke
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3595
1: get an electronic crossover that takes one or two sets of inputs and splits to front/rear/sub out. that'll hendle splitting signals to teh 6 amp channels
2: run 4ga cable from the battery to the amp location.
then use a distribution block with fuses to split the power to each amplifier with 8ga wire.
