Small subchoices
Username: Dodgedifferent2
Windsor, Ontario Canada
Post Number: 100
Ok i have a very tight spot to place my sub.
I am planning on putting a sub behind my rear seat in my 03 quad cab dakota. I plan on using a 10" sub
Very tight spot so the plans are to make it a sealed box. the box would measure 14" tall, 25" wide, 4" top depth and 7" bottom depth. I may have to somehow make the box wider but it would no longer be a neat box it would have to go over the seat mounts in the truck. so it would be an odd shaped box.
The shallow mount woofers that i am considering at this moment are
1) kicker 07cvr10-4, 25-350 hz $119.00 cdn
2) pioneer ts sw251, 20-144 hz $229.00 cdn
I mainly listen to Metallica and country music. I already installed alpine sps 600 and alpine 600c in my truck doors.
I am using a clarion dxz765mp head unit
Which unit should i go for? or is there a better choice that i can get?
I do not have an amp at this moment and i did not want to spend more then $500 on these two items.
Username: Kyle_lowe
Post Number: 978
you should hold out for a bit to see how much the new si bm's are going to run
http://www.stereointegrity.com/
Thamesville, Ontario Canada
Post Number: 101
looks like 260 usd ... plus shiping and customs charges ... BAH!
But they do look pretty sweet from what i have read so far.....
Username: Kyle_lowe
Post Number: 981
ahh i didnt know how much they were going to be
there are obviously other good options i only said that because i thought it would have been cool if you could have gave us a nice review
Post Number: 102
ok i ended up finding an Alpine sws-1043D for 149 at bestbuy.
The mounting depth seems like it should work at 4.3 inches. It will be tight... but i am hoping it works. I will be building the box next week. Then i will know for sure.
Also the pioneer amp d 1 channel (gm-d7400) went on sale at futureshop for 179 from 239. So i grabbed that as well.
Should they work well together?
