What do you use?
Username: Drinsano
Michigan
Post Number: 8
Hi, What kind of amplifier do you use in your system? I'm just looking for whats popular.
Second Question, I have a DVC Infinity Perfect 12.1 Subwoofer, 4 ohm per coil. I want an amp that will power it perfectly, and am looking at between 400 and 500 watts RMS, as what I'll need, any suggestions? Thanks! Also I want the amp to be less than 300 or in the 300 range if possible
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3582
JBL BP300.1 for your sub.
I'm using all first and second generation Orion amplifiers myself.
1 2125SX, and 3 2250SX amps.
Username: Pat_l
Tucson, AZ USA
Post Number: 323
Go with the JBL
fdasfd
This is Ryan, having log in trouble......
is that JBL 300.1 enough? it says it only pushes 300 watts
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO301.1&ser=GTS&cat=AM P
Only JBL I can find thats close to what your talking about at JBL's website, Infinity says that the Perfect 12.1 needs 175 watts per Coil, and that would only give me 300 watts total, which is 150 per coil, but I'm really a noob at Amplification, so if I'm wrong please tell me where thanks Also, would a Zapco 500.1 be too much power? or an MTX Thunder801D ? I'm really confused, just want to get the loudest, best sounding bass I can out of this single sub.
fads
oh ya, when I said less than 300 I meant Dollars, not watts :P
