Clarion radio code
Username: Magnum100
England
need code for clarion pu-2294b serial number cl040220823887
Username: Misha88
Hello! make attempt 4455, if will walk up write to me.
with kind regards Mikhail.
Username: Regrooster
Post Number: 3188
4455 is not the correct code
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
