Captive works releases new private bin
Username: Tapeman
New York Citay in-HD, NY
Post Number: 4536
I just got the word that CW released new private bin 3 days ago
Mainly for CW700 and CW800
It's unclear if it's a cardless or via IKS
Yo can actually get the bin from currentbins.com
Also be aware of FTAHQ is forwarded by runawayrentals.com
Not sure if it's hacked or what
We may see PTA back in action soon
Username: Plymouth
Post Number: 12638
King
It is a private card sharing!
Username: Hardwarecrazy
Post Number: 161
Plymouth, how do you use CW with CS? Can you elaborate?
Username: Tapeman
Post Number: 4537
They haven't realesed the dongle link
tested as private not public
Username: Plymouth
Post Number: 12641
Hardware
I've not tried this private card sharing but usualy but on most of Private CS, they use a card reader inserted between the smart card like the old card to put on sub to get the control work which is send via ethernet to other FTA!
Username: Plymouth
Post Number: 12642
King
You are right!
No mention of Hub, I will do a search to see if they will put one on market!
CW has 2 receivers with ethernet port but 700 and 800 doesn't have this!
Username: Plymouth
Post Number: 12643
Description & Contents
TheCaptiveworks Dongle is the most advanced usb-to-ethernet converter. The Captiveworks Donglesupports media delivery over ethernet via the USB port of your Models CW-700s, CW-800s y CW-ULTIMA.
Spec&Features
Specifications
The following specifications will give the technical savvy person an overview of the Captiveworks Dongle design and an understanding of what the Captiveworks Dongle is capable of. Please be aware that specifications are subject to change at any time.
Architecture
+ TCP/IP: W5100
+ PHY: Included in W5100
+ Serial: RS-232
+ MCU: 62K Bytes in-system programmable (ISP) Flash
Network
+ Interface: 10/100 Mbps auto-sensing RJ-45 Connector
+ Protocol: TCP, UDP, IP, ARP, ICMP, MAC, PPPoE
Serial
+ Signals: TXD, RXD, RTS, CTS, GND
+ Parameters:Data bits: 7,8 | Flow Control: RTS/CTS, XON/XOFF
+ Speed: Up to 230Kbps
Other
+ Dimensions: 3in x 1.5in (PCB length x width)
+ Power Consumption: DC 5V, Under 180mA
+ Temperature: 0c ~ 80c (Operation), -40c ~ 85c (storage)
+ Humidity: 10 ~ 90%
http://www.youtube.com/watch?v=aEcKoCOd818&feature=player_embedded
This hub use the USB port against serial!
Username: Daneegha
Post Number: 189
Any idea of how much????
Thanks!
Username: Plymouth
Post Number: 12645
+ -100$ us
Username: Nydas
Post Number: 17859
The CaptiveWorks dongle for 700s and 800s has been around for over 3 months. It is strictly private card sharing and the prices people are quoting as exhorbitant.
