What are a good set of tweeters
Username: Carpetking
i have 4 10 inch voice speakers i need some tweeters to go with them
Username: Delsole
Post Number: 1444
What kind of speakers are they, what do you have for power to the speakers, and what will be used to power the tweets?
either way if your going that way i would probably suggest a couple selenium super tweeters or a couple selenium horns. Eminence also makes some nice tweeters.
