New member Username: Mjr87Vancouver, B.C. Post Number: 2 Registered: Mar-10 | i have a 2009 gmc sierra just wanted to hook my kicker slim truck sub wit box up i have an new alpine 1000 watt mono amp. someone told me just to hook it up to the rear speaker wire or something. just wondering any suggestions and i want to keep my stock head unit in. all im wanting is my sub hooked up and the cheapest way possible cuz im broke as hell right now. i was thinkin just buying was power cable with the line fuse, ground cable, rca cable, remote cable, and speaker wire for sub. if u have any suggestions for wiring or how i should do it let me know..much appreciated thanks! |
Bronze Member Username: M_kimmel843Post Number: 72 Registered: Apr-10 | Buy a high level to low level converter. What you do is take to converter and splice your two rear speakers into the converter by tapping into both rear speakers positives and negatives. This is easily done using wire taps that you can buy at a local Radio Shack. What this does is turn the high level signal into a low level signal that your amp can pick up using aftermarket rca cables. Any more questions just ask, this was kind of a quick overview of how to do it. If needed I will go into more detail. |
New member Username: LongbeachPost Number: 3 Registered: Jun-10 | JL makes a great conversion made easy, check it on their website. http://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94 |
Bronze Member Username: Joe1234Post Number: 17 Registered: May-09 | Something like this if you are broke: http://www.amazon.com/GSI-GGLOC2-High-Level-Converter/dp/B001O0MT54 And also you need to use the amplifier's low pass filter. |
