Need some help, will this work???????
Gmc2500
i am going to have to bend the port for my box,its going to be made out of pvc pipe and will keep the 3 inch diameter the whole way through, if i bend it in one spot 90 degrees will it still tune the box correctly, i was told this would work by the tech support at rockford, but wanted to see what yall though before i tryed it, thanks
Username: Rswan
Post Number: 140
it depends on the port placement.
Gmc2500
how do i need to do it to make it work?
Username: Rswan
Post Number: 141
place the port so that the open end inside the box is facing the same wall of the box that the subs magnet is.
