david33 Unregistered guest |
Posted on would it be a bad thing to have 2 kicker cvr 12's in a triangular box about 2.25 cubic ft. with a 3inch tube port on each side of the box? |
Posted on c'mon someone has to have a opinion |
Bronze Member Username: Rollinondubs
Post Number: 23 Registered: Mar-04
Posted on Nope |
Posted on so u think this would be a decent setup i like loud boomy bass so should i do this or just go wit a seald box?
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 303 Registered: Apr-04
Posted on Judging by the calculator on 12volt.com the port needs to be 4.7in long, that set up will work fine. Its very common. |
Posted on cool thanx for the help |
