Setanta sport
Username: Puchatek
Post Number: 27
How to get setanta sport on FTA and how to setup ECHOSTAR9 OR GALAXY 23
Username: Dumbley
Post Number: 8
Setanta sport @ 101w AMC 4- you would need a 30" or larger dish and a lnear lnb,
Normally you would do your antenna settings for the sat you want to get signal from and select an active TP ( you can use lyngsat to find this info - setanta sport @ 101w is on TP 12159 V sr. 30000 ) , then aim dish till you get the best quality you can - I use dishpointer dot com to aid in aiming the dish.
Then blind scan to get all the available channels on that sat.
GALAXY 23 , is c band and would require much larger dish and proper lnb
Username: Puchatek
Post Number: 28
thanks Dambley.
Username: Califirnia
Post Number: 93
Setanta Sports US Service to End February 28, Reports Say
http://www.epltalk.com/setanta-sports-us-service-to-end-february-28-reports-say/ 14882
