New member Username: LarsltdPost Number: 1 Registered: Jun-04 | Basically I got a sony CDXMP80 head unit, and have just got a sub with built in amp ( it was cheap off my bro and i want to complement my 1000w kenwood amp running my 2 6X9's! ). on the back of my head unit i have mono sub output with two white wires (for 2 amps ?). can I use a set of rca's l/r to l/r with this connection on my head unit ? the reason i ask is cause my amp has a l/r input but no mono input so how do i get around the problem of mono output - stereo input ? Thanks for help Chris. |
Bronze Member Username: JamtochristianWilliamsport, Pennsylvania USA of course! Post Number: 79 Registered: Mar-04 | Looks like it probably only has a mono sub out, no surprise. Just run your RCAs from those two whites to the sub. That'll work just fine. Or, if you don't wanna do that, then get a splitter, put that on one of the white outputs for the sub, and then run the L/R of the RCA to your subs that way. Either way, should work just dandily. Hope this answers your question. |
Silver Member Username: RswanPost Number: 121 Registered: Apr-04 | first of all why do you have a 1000w amp running two 6x9's? second how old is your hu? ive never heard of a mono output from a aftermarket hu. |
New member Username: LarsltdPost Number: 2 Registered: Jun-04 | Cheers Donald R, was gonna try that just wanted to check that it would work!. P.s. I have a 1000w cause i wanted to have the ability to upgrade my system without needing new amps plus running the amp at half power will make it last longer!, now all i gotta do is wait for me distribution block and all should be dandy ! Cheers for the advice chris |
New member Username: LarsltdPost Number: 3 Registered: Jun-04 | My head unit is : http://products.sony.co.uk/productdetail.asp?id=3_34_2468 p.s. amp is 1000W max so only runs at 2X150W rms! hence is ok for 2X 6X9's ! |
Silver Member Username: RswanPost Number: 123 Registered: Apr-04 | i didnt know they made hu's that have mono outputs. doing what donald said is the way to go |
