Bronze Member Username: Lion_cingPost Number: 33 Registered: Sep-06 | Hello, I have a HP Pavilion Dv5-1160US on Vista with HDMI or VGA connection; would like to use my Sony Tv (CRT - Only analog connection). I have tried VGA to RCA cables and HDMI to RCA (Yellow Red White cables) but no luck. Please help anyone |
Silver Member Username: Ieee488Post Number: 255 Registered: Dec-07 | The reason cables don't work is because the signals are NOT the same. You can't just connect them up and expect anything to work. You must by a converter box - either VGA to composite video converter box or a HDMI to composite video converter box. The former is cheaper. Which type you choose to buy is up to you. Be sure to read the reviews. http://www.newegg.com/Product/Product.aspx?Item=N82E16815158142&cm_re=vga_conver ter-_-15-158-142-_-Product |
