Bronze Member Username: Glock40Post Number: 11 Registered: Jul-09 | What is the best components around 100-150rms, that will have LOUD MID(voice), and decent loud highs under 200 ive heard the Infinity Reference 6020cs with 85rms each, and dont like em, they have a weird not clean sound to me.i want something not as harsh as the infinity's, but cleaner with no distortion turned up i want clean and loudest mid i can get under 200 maybe one of these would be cleaner??? http://onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17563 http://onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15026 http://www.woofersetc.com/p7444/CL625CV--CDT-Audio-625"-Convertible-Component-Coaxial-Speaker-System.htm |
Bronze Member Username: Arsenault_denisPost Number: 21 Registered: Dec-04 | The Diamond Audio D6 seems to fit your description pretty good. There might be others that can offer more suggestions but from what you got listed there, I'd go D6. As for sound not being harsh, keep your selections to silk or soft fabric tweeters compared to metal tweets and you should be fine. As for the Infinity references, I used to have a pair 5 years ago and didn't mind them. they were a good buy for the price compared to the stock speakers in my car But then again, I had to do a lot of tweaking to the crossovers, the amp and HU settings to get the sound I was looking for. |
Bronze Member Username: Glock40Post Number: 13 Registered: Jul-09 | thanks dennis |
New member Username: Carlionne1Post Number: 1 Registered: Aug-09 | this is the best ive ever heard for the price ofcourse Boston Acoustics SL60 http://techronics.com/caraudio_3167_Boston-Acoustics-SL60-6-1-2-inch-Car-Audio-C omponent-Speaker-System.html |
Bronze Member Username: XxemoxxHermosa beach, Cali Post Number: 16 Registered: Sep-09 | I like the D'6's and the SL60s' and that is an amazing deal on the Bostons. I personally want to hear a set of the new MB PVI's but am weary as most places around where i live dropped the line when they moved production to china. Also I am a big fan of the new ADS stuff. |
New member Username: Rgp12000Post Number: 1 Registered: Sep-09 | yeah the diamond audio ones are good i hear |
New member Username: Lil_semsVa Post Number: 4 Registered: Oct-09 | american bass sq65m - u havent heard loud n clear till u have heard these |
Bronze Member Username: Desmo4usaModesto, CA USA Post Number: 12 Registered: Jul-09 | Focal, I have 165-K2P's and they are the best I have heard, but Utopia BE if your pockets are full of $$$$$$$$. I used to have MB Quart 218.16's made before they were sold and the quality was destroyed and they were very good. But the Focals are many steps ahead. I have an S2000 and am not running a sub. I have pushed the bass on my 475 Ti and have no desire to add a sub. |
Bronze Member Username: BookeeperLouisiana Post Number: 25 Registered: Jan-10 | boston acoustics yo or maybe try rainbow but i see rainbow are high prices |
