Custom Sub Box for a ford Escort Wagon
Username: Gcs7th
NY
I just wanted to get some opinions on the box i built for my friends car. I think were gonna use a kenwood 800 watt 2 channel amp 2 drive the 2 pioneer 12 in subs. {the box is 3.5 cu ft, and pioneer reccomends 3.3(1.65 each)for what would be 2 subs}[the box is made of 3/4" particle board, glued and caulked]
http://www.geocities.com/w_s_productions/subbox.html
its not quite finished i just gonna put in the port tubes when they come from crutchfield ( 4 2in by 5" tubes) and they amp will go in the center plate. Send me some comments. Gcs7th@aol.com
Username: Pat_l
Tucson, AZ USA
Post Number: 270
I think its nice, the AMP in the middle will tie it all in. I think it needs to be recarpeted with black. The grey is kind of plain and has some holes. Other than that it should be cool. You may want to tie in some neon around the subs or something, to punch it out a bit.
Username: Gcs7th
NY
For some more info i'm most likely using this AMP
http://www.kenwoodusa.com/product/product.jsp?productTypeId=11&sortBy=price&page Id=2&productId=2478
and these are the subs for those who are curious
2076_4061_10473921%2C00.html,http://www.pioneerelectronics.com/pna/product/detai l/0,,2076_4061_10473921,00.html
