Well im only gonna run one sub so the dvc 4 ohm sub wired in series will give me a 2 ohm load.
kickercomp
i have 2 comp vr 10s (4ohm dvc) in two seperate slot ported boxes with 250watts running to each box. this setup is very loud due to the type of box you can get, becouse if the box is just right it will add much more dBs. i think the 4ohm models are easier to match up to 2channel amps. any way 140dBs is great for 2 10s
