NO AUDIO
Username: Jftaylor77
Hi folks if anyone can help me you will make my day, so here it is i have a samsung 52" lcd tv connected dvi to hdmi cable between computer and TV thats OK, standard audio LR cable from tv to LR Y connector 3.5mm NO SOUND used different set of audio cables still no sound updated drivers still nothing the samsung manuel gave me instruction on how to hook up via HDMI. Running windows 7 Pro GiGabite P31 ES3G vid card Nvidia 9500 GT 1GB.
Thanks
Username: Ieee488
Post Number: 237
You need to verify that you are running cables to the audio IN on the TV and not the audio out
Username: Guile42
Manila, Main Philippines
Post Number: 8
hi, ive gt the same problem before with my hp laptop and i downloaded some software for videos to make it run, for the desktop there might be some of software also that can be use for your nvidia,. check some audio softwares in drivershq.com or with the website brand of your desktoppc.
Need to Register?
Forgot Password?
Enable HTML code in message
