Username: Domenico BanginGMCUSA
Post Number: 368 Registered: Apr-09
Wednesday, January 13, 2010 - 07:10 GMT Looking for a handheld one that reads up to 150/160. Any ideas where to get one? - Thanks Dom.
Username: Basebalz13 Moneta,
Va
Usa
Post Number: 1975 Registered: Aug-07
Wednesday, January 13, 2010 - 15:13 GMT none, invest in a TL if you want to get serious, if not check out audiocontrol epic 160
Post Number: 369 Registered: Apr-09
Wednesday, January 13, 2010 - 15:19 GMT Audiocontrol epic 160 looks sweet, that shows the voltage gauge too right?
Username: Insearchofbass York,
Pennsylvania
Post Number: 13001 Registered: Jun-04
Wednesday, January 13, 2010 - 15:40 GMT I have a dbm2 thats pretty good that goes up to 150 db but its not 100% accurate. The most accurate would be a termlab which you would need to run with a laptop and it would cost you 500 used with a mic.
Post Number: 372 Registered: Apr-09
Wednesday, January 13, 2010 - 17:45 GMT I just want one because I'm curious, I don't wana drop bank on something I'll use a couple times, ya smell me? Sean- where'd you buy yourS?
Pennsylvania
Post Number: 13008 Registered: Jun-04
Wednesday, January 13, 2010 - 18:29 GMT The company I bought my meter from is out of business. Best thing for you would be to get tested by a shop.
