Denon receiver and vintage turntable
Username: Jtnewlyretro
I am stereo system novice that recently purchased a 1969 Dual 1264 turntable. I'm attempting to hook it up to my Denon AVR-688 receiver... however, the amp does not have a "phono" input nor a grounding post. I have successfully connected the grounding wire to a screw on the back and have tried the channel cables in both the "CD/Tape" input as well as the "Aux" input, but the sound quality is terrible. Grounding it helped get rid of the some of the buzz/hum, but the volume is extremely low and I'm having to turn the master volume almost all the way up in order to hear music.
Any suggestions? Your help is appreciated!
Username: Magfan
Post Number: 754
You need a phono preamp stage between the receiver and the TT.
Modern (alledgedly) receivers omit that section since so few would know what to do with it and backpanel space, not to mention internal space in the receiver is at a premium.
someone will be along in a minute to make a phono preamp suggestion.
Username: Jan_b_vigne
Dallas, TX
Post Number: 14326
Best for the money, the Belarri; http://www.soundstage.com/vinyl/vinyl20080615.htm
Good for less money, the NAD; http://www.tnt-audio.com/ampli/nadpp1_e.html
Cheap, gets the job done; http://www.phonopreamps.com/
What phono cartridge do you have on the table?
