Jvc gr 270 stuck in safegaurd mode
Username: Dmc2112
jvc gr 270 stuck in safe gaurd mode. display keep sayin 'unit in safegaurd mode eject and reinsert tape 03'. i have done this several times with no results. in the trouble shooting section in the manual 01-06 seems to be error codes but i cant find anywhere that explains each code. can anyone help!!
Username: Desertwest
I MADE MINE WORK!!!! With the camera off, I pressed and held the "play" button while I powered it on into playback mode. It actually let me watch the tape. I switched it to "REC" mode and still got the error. So I switched it off, pushed and held the rec button while powering it on... IT WORKED. Now I can power it on and off with no more error messages (so far)! Let me know if this works for you too!
Need to Register?
Forgot Password?
Enable HTML code in message
