What setup should I do
Username: Tweezy79
Chatham, Il
Hi, yall. Im new to the forum and could use some suggestions on what kind of a setup I should do. I have a 2001 Ford F150 Supercrew truck. I am wanting to put a box under the back seat. This is my only option to put subs in my truck since I have children that ride with me on occasion. I am looking for some real deep bass since I listen to mainly rap. I am going to have a local stereo shop make me a box for my setup and have the most of 1.3 cubic feet of air volume and a mounting depth of 6.5 inches. They will also make enought room for a xmass of about 30mm. My amplifier is a Kenwood Excelon 1600 running at 912 rms at 2ohms. Here are a couple of options I have came up with. I am wanting to put in 3 Kicker L5's running at 300 rms at 2ohms a piece. My second option was going with a FI BL 10 inch woofer running at 1000 rms at 2 ohms. Any thoughts or suggestions would be great. Thanks for the help.
Username: Tweezy79
Chatham, Il
Oh yeah, and by the way. The 3 kickers will be in a sealed box and the FI BL will be in a ported box. Hope this helps.
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 1109
FI>Kicker
Username: Loc_out
SoCal
Post Number: 3058
Your box is going to be 1.3 cubic feet all together? Or per chamber?
Username: Tweezy79
Chatham, Il
1.3 cubic feet all together. I dont have that much room under the seat due the seatbelt being in the way. I have been reading about the treo ssp line. What do you think about treo versus FI? The new Treo SSP 10 inch woofer has an rms of 1000 at 2ohms. My amp should have no problem pushing that sub.
Username: Loc_out
SoCal
Post Number: 3060
I just saw some picture and the magnet looks pretty big. Couldn't find spec of it.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10880
Two Fi Q 10" sealed would own...
ficaraudio.com
In fact that is my exact setup
Username: Tweezy79
Chatham, Il
I have read up on the Q's but I thought they would be more for sound quality over spl. I am looking for some real deep bass.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10885
Low end and SQ are what the Q is for.... SPL subs do not do as well in the deep bass.
Username: Tweezy79
Chatham, Il
So with some more research and video downloads, the Q's do sound like a good idea. But now I have a problem with the amp not putting out enough power to push em. Could I hook that amp up to the Q's for a couple of months and then get into another amp? The amp is only 912rms at 2ohms.
Post Number: 1113
or you can sell that amp and pick up a better one
Username: Armykyle1
Ms Us
Post Number: 837
If the RL-i 10s fit they produce very clean low bass. Also memphis line of shallow mount subs are very nice 10s that is compared to JL or pioneer. Diamond D3 10s will sound very nice too. They're rated for 400rms but they'll handle 500 to 600.
Username: Tweezy79
Chatham, Il
Post Number: 10
The memphis line is very solid, but I am kinda on a budget since I have a new family member on the way. I would like to continue to use what I have and spend no more than 400 on the subs. I think I am going back to the 3 8 inch Kicker L5's or single 10 inch Treo SSP. I have heard the kicker setup before and it does sound really good. I wonder if the 10 inch treo will put out more low end bass. Any thoughts?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10890
Kicker square subs are terriable just an fyi
Username: Tweezy79
Chatham, Il
Post Number: 12
All right, I took the plung and got the treo ssp 10. Everything wil be getting hooked up real soon and cant wait to see what the outcome is. Thanks for all of the tips and suggestions. This forum is great.
