New member Username: Mattwood1000Post Number: 5 Registered: Dec-09 | i am looking to install a kicker dcvr12(peak:1600 watts, rms:800) and kicker zx750.1 amp (750 watts @ 2ohms). Would the big 3 upgrade be needed in my 2003 subaru outback to sufficiently power this setup |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15784 Registered: Jul-05 | i wud advise to have it done ... |
Gold Member Username: Killerzracing71Post Number: 2409 Registered: Aug-05 | Its benifical without a system too. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10884 Registered: Jul-06 | If your alternator and battery are stock you would most likely not see any difference. |
Gold Member Username: DelsolePost Number: 1441 Registered: Feb-05 | I have noticed a difference on cars with no system... and besides for the price it really cant hurt. |
New member Username: Tweezy79Chatham, Il Post Number: 8 Registered: Dec-09 | Will local car stereo places install the big 3 or is this something that can be easily done by yourself? I have read aboput the big 3 but cant find kits online. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 21724 Registered: Jun-06 | If you can turn a wrench you can do it yourself. Save yourself the $$. You'll need some good 1/0 wire and some terminals. Try http://www.knuconceptz.com |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15787 Registered: Jul-05 | shud have alot of articles about this online & youtube has vids too ... |
Gold Member Username: Killerzracing71Post Number: 2410 Registered: Aug-05 | http://www.youtube.com/watch?v=iX9Rcq5DnKw Why wont you notice a diff? It can help it charge quicker, and more efficently, and discharge quicker to. Alt has less stress on it.to flow electricity. |
Silver Member Username: Armykyle1Ms Us Post Number: 835 Registered: Dec-08 | I went from 13.4 to 13.9V. Now with the big batt I'm sitting at 14.4. But after the upgrade I noticed a smoother idle. |
