2001 Volkswage GTI Radio Code
Username: Zandonagti
I've read different posts and have a pretty good idea of what to do as far as re-activating my radio.
The only thing is I thought I had the code but after my first attempt, the radio went into "lockdown" mode and now I need to start over.
1- Is the code in any of these pics?
/Upload
PDF_005.pdf (81.5 k)
2- Just to make sure, I will need to keep the key in the "on" position for about 1 hour in order to have a second shot at this?
3- What if I disconnect the battery and reconnect it? Would that do the same as the 1 hour waiting period?
Thanks in advance
PDF was to large
/Upload
PDF_004.pdf (96.0 k)
Username: Regrooster
Post Number: 2898
Main VW Dealer or Decode Service only for your code
So you don't think the code is 1098 as one of the pics show?
Post Number: 2903
If the radio did not accept it , then it is not the correct code
I'm in need of help here.
Any chance the code may be 1164, that is based on what's right below the vin # on the sticker except that the whole thing is 1J16N4
Post Number: 2914
Unfortunately the majority of VW Codes (including yours) are only available from the Main VW Dealer or a Decoding Service
If you think you know the code , then try it.
