New member Username: Latvian86Post Number: 1 Registered: Dec-09 | What is the best ohm level for subs if i have a Kicker zx 1000.1 amp?? |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 4167 Registered: May-07 | 2 subs- 4 ohm (svc) 2 ohm (dvc) |
New member Username: Latvian86Post Number: 2 Registered: Dec-09 | So would 4ohm subs be better than 2 ohm subs or vise versa? is that a measure of the amount of power going through them? thanks |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 4168 Registered: May-07 | http://www.the12volt.com/caraudio/woofer_configurations.asp try to match the total rms of sub (s) to the rms rating of the amp. example- amp zx1000 1000 wrms @ 2 ohm 2 subs/ ~500wrms rating each 1sub/ 1000 rms the voice coil needed is determined by he amount of voicecoils that are on each sub (SVC, DVC and quadvc(rare)) andthe ohm load desired to get the most out of your amp. in ex- 2 ohm would be what your sub(s) need to be wired too. . once you know the amp needs a 2 ohm load to reach 1000wrms, then you know what ohm vc to get in whatever vc configuration of desired sub(s),. Hope this makes since. |
New member Username: Latvian86Post Number: 3 Registered: Dec-09 | Could I get 2 JL 12w6's (4ohm) for that amp?? Im still looking for the right subs...any suggestions?? |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 5504 Registered: Dec-06 | You could run the W6's but they don't make dual 2's like you need and you could do better for the money like the AQ 2.5, or JBL P1222. And those will match your power better. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 5507 Registered: Dec-06 | You need this: ![]() |
New member Username: Latvian86Post Number: 4 Registered: Dec-09 | Nice, thanks a lot... One more thing, Im not caught up on my subs... whats the AQ 2.5?? |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 5509 Registered: Dec-06 | Audioque http://www.audioque.com/aq/ |
