New member Username: MattwedemPost Number: 9 Registered: Nov-09 | I am replacing my speakers and need more power so I am buying an amp. My question is will this amp work? http://www.caraudiodeals.com/autotek-at1200-p-2637.html If not what are some amps that would work? Thanks |
Silver Member Username: Nick_belskyNorth Canton, Ohio USA Post Number: 121 Registered: Nov-09 | If it doesn't, you should be able to return it to whom you buy it from and ask them why it died... |
Bronze Member Username: Vai4meMichigan USA Post Number: 73 Registered: Dec-04 | Don't you just love blanket questions like these? |
Silver Member Username: SkdooleyRoanoke, VA Usa Post Number: 162 Registered: Oct-09 | Any amp will "work". You need to look at the rms it is producing per channel versus what your speakers run at. You also need to go by them name, normally a brand that is more well known, fosgate, alpine, JL, just to name a few will produce the power they claim. Other brands that appear to be "cheaper" in price, normally dont produce all of which they claim to. That is something to keep in mind. |
Bronze Member Username: Vai4meMichigan USA Post Number: 79 Registered: Dec-04 | Shawn, I couldn't have said it better myself. |
Silver Member Username: Nick_belskyNorth Canton, Ohio USA Post Number: 127 Registered: Nov-09 | I third that notion! |
