HI all can any of you clever people help me with a radio code for my renault laguna 2004 with a cabasse aditorium cd fitted.The fuse had blown (which took me ages to find as the french hid it under the ash tray) serial ALR92S40347527 rest of numbers on set are 8200318360r t40347527 alr925 47527 5833 chers peter
HI all can any of you clever people help me with a radio code for my renault laguna 2004 with a cabasse aditorium cd fitted.The fuse had blown (which took me ages to find as the french hid it under the ash tray) serial ALR92S40347527 rest of numbers on set are 8200318360r t40347527 alr925 47527 5833 cheers peter
Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
