Headunits (OT) 24 bit brown burr vs 16 bit
Username: Mendonmafia
Post Number: 1872
can anyone tell me if tis worth going from the 16bit dac the the 24 btis brown burr?
The pioneer 980 has 24 bit but dosnt have a bunch of things the 710 has that i want (direct ipod included, usb) but i want to have clear sound.
The 980 also has 5 volt pre outs and the 710 only 4.
Is it worth it? Im an sql guy and have an atomic 3k for my subs and 150 rms each side feeding my front comps.
Username: Philly306
If youre going to give...
Post Number: 1500
a 24 bit DAC is in fact better but you wont here a difference in a car playing mp3s
Username: Insearchofbass
York, Pennsylvania
Post Number: 12910
uncompressed music for the win
Post Number: 1873
well since 99% of my music is on my ipod i guess im going with the 710.
Thanks.
Would the difference be audible playing cd's?
Username: Philly306
Post Number: 1501
between a 16bit and 24bit in a car? nope
Post Number: 1877
thanks phil. I got a 710bt on the way :-)
