Speakers cutting out when bass turns up
Username: Texasmade89
Hi im new to the forums.
I have 2 15 inch kicker L7 subs running to a 5500 watt power acoustics amp. I also have 4 pioneer speakers running to a 1200 watt pioneer amp with a pioneer head unit.
The problem is when I crank the system up the speakers cut in and out but when the volume is down i have very little problems.
My installer said I need a new alternator and second battery because the system pulls to much power. I don't think this is right.
Help Please
Username: Vai4me
Michigan USA
Post Number: 58
Sounds to me like your installer is on to something, if you are truley producing that many watts then you are more than likely pulling far more amps than a stock alternator is able to produce...just my 2 cents...
