So I drive a '99 Integra and just got a 10" rockford fosgate sub. The model number is P1S410. I really know almost nothing about car audio equipment and the way it works. I'm not a complete moron with electronics, but I definitely could use some help.
So I guess my question is what should I do about an amp and an enclosure. I believe those are the only things I need at this point. The power rating says RMS 150 W, and Peak 300 W. I know those numbers are important, but I don't know how to interpret them. Any recommendations on what power amp I need? And what about the box size? And do you recommend it be sealed?
Yep, The P1. You won't need a big amp at all to power that.
Since your speaker is a single voice coil 4 ohm driver, you need an amp that puts out 100-200 watts at 4 ohms. what is your budget for the amplifier?
as far as the box, i can design or build one for you at a small cost. just shoot me an email in my profile. The box will be designed specifically for the speaker.
