Hi, just wondering if you can help me, I lost my code for my radio, currently in safe mode. 2001 AUDI A8L Radio serial # AUZ5Z4Y0104608 VIN#WAUML54D21N001199
============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Post Number: 1 Registered: Nov-09 Posted on Saturday, November 21, 2009 - 08:09 pm:
Hi,
Any chance of getting the code for a peugeot 206?
Serial: CL0410Y0128220
Model: PU-2325A(B) -------------------------------------------------------------- Please quote any numbers beginning with C7000000**** found on any barcodes.
Could someone help me to recover security code for my radio? Details: Car - Audi A4 1996 Radio - beta auroreverse Numbers from side of radio - 7 644 845 380 AUZ1Z2T4700577 400 035 152
Post Number: 1 Registered: Nov-09 Posted on Sunday, November 22, 2009 - 02:55 pm:
HI I have a 2006 Acura TSX, radio serial # U 1000 L 0539
Any help would be greatly appreciated. Thank you! =============================
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Post Number: 1 Registered: Nov-09 Posted on Sunday, November 22, 2009 - 01:34 pm:
Hi,
Could someone help me to recover security code for my radio? Details: Car - Audi A4 1996 Radio - beta auroreverse Numbers from side of radio - 7 644 845 380 AUZ1Z2T4700577 400 035 152 ====================================
Unfortunately the majority of AUDI codes (including your Blaupunkt ) are not available for free from anywhere on the Internet.
Only available from your Main Audi Dealer ....or a Decoding Service who will connect it to a laptop to read/recode the memory chip (EEPROM)
I had to disconnect my battery to replace clutch cylinder and need the radio code. Have a 2000 Acura Integra. My radio model number is 39100-ST7-A500. Serial number is 96F517929. Any help would be greatly appreciated!
Post Number: 1 Registered: Nov-09 Posted on Monday, November 23, 2009 - 12:31 pm:
I had to disconnect my battery to replace clutch cylinder and need the radio code. Have a 2000 Acura Integra. My radio model number is 39100-ST7-A500. Serial number is 96F517929. Any help would be greatly appreciated! =================================
The only free source for Acura is here https://radio-navicode.acura.com/?src=inq
If they cannot help , then try the Honda Main Dealer or a Decoding Service
Post Number: 2 Registered: Nov-09 Posted on Wednesday, November 25, 2009 - 06:18 am:
Hi i need code for Philips car 400 no: 93172248 TYPE: car 400 s.n GM040023202934 barcode1: 9022 213 99784 02 barcode2: 003 0204 3202934 -------------------------------------------------------------
Sorry...not in my Philips database
Main Dealer or a Decoding Service only for this code
Please note:
Post Number: 1 Registered: Nov-09 Posted on Saturday, November 28, 2009 - 10:59 am:
Please help me with the radio code for my Peugeot 206. I
Clarion RD3-01
The Serial Number is CL054210047831 The Part Numer is PU2471A =================================== The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Post Number: 1 Registered: Nov-09 Posted on Saturday, November 28, 2009 - 12:14 pm:
Hi,
Can anyone help with a lost radio code for a Siemens VDO CDR 500 in a 54 Reg. Vauxhall Zafira?
The serial number is: GM050042233321 Siemens 330886636 No 93171870 ------------------------------------------------------------------
Unfortunately the majority of SIEMENS/VDO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Hello All, Same story as many, battery went dead and now no tunes. I have a BMW 2002 Z3 in US. Numbers as follows: 65126909885 BP 027329976038 FD 192 Index 45
Any Help would be great. Also How do I get rid of "code Wait" that comes up after trying the wrong numbers?
My Rover Mini MPi had a different unit installed when I bought it (which has now broken) so I need the code to activate the factory-fitted cassette player.
I'd be really grateful if you're able to help!
Rover/Philips Cassette/Radio Type: 22DC349/60S RG Part No: XQD101050 FD: 09 99 13 8007253 Serial No: RG349FX8007253
Post Number: 1 Registered: Nov-09 Posted on Sunday, November 29, 2009 - 06:05 pm:
Hi,
Rover/Philips Cassette/Radio Type: 22DC349/60S RG Part No: XQD101050 FD: 09 99 13 8007253 Serial No: RG349FX8007253 ======================================
Post Number: 1 Registered: Nov-09 Posted on Sunday, November 29, 2009 - 02:26 pm:
Any Help would be great. Also How do I get rid of "code Wait" that comes up after trying the wrong numbers? -------------------------------------------------------------------
Try code 7450
To restore from WAIT leave SWITCHED ON until it resets itself. It could take several hours
Post Number: 1 Registered: Nov-09 Posted on Monday, November 30, 2009 - 09:10 am:
Hello.
I need a code for my MB Original Radio. (1997) It's a Becker BE2010, and the serial number is: T1816536 ------------------------------------------------------------
I need the code for my Phillips car stereo. Type - Rover 22DC745/60B RG part nr. XOD101091PUY Philips nr. RG745WY1064746 thanks for any help.Could anyone help me ?
Post Number: 2 Registered: Nov-09 Posted on Monday, November 30, 2009 - 04:22 pm:
Hi first of all.
I need the code for my Phillips car stereo. Type - Rover 22DC745/60B RG part nr. XOD101091PUY Philips nr. RG745WY1064746 thanks for any help.Could anyone help me ? ====================================
Sorry...not in the database
Main Dealer or Decoding Service only for this code
Hello, Hope someone can help me with the code for my old stereo. I had my nice one stolen from my car recently, and have decided not to get a new one, as selling car shortly so going to put back in the old cassette version that was original with the Peugeot 206. RETRO or what...lol. I just need the code to get it working again...can anyone help?
Details as follows:
Peugeot T1 LOW
BP8140X5419755
7648140392
96 251 330 80
If someone can help me out, that would be great. Only have numbers 1-6 on front of stereo. At least i'll be able to pick up radio.. YEY. :-)
Post Number: 3 Registered: Dec-09 Posted on Tuesday, December 01, 2009 - 05:18 am:
Details as follows:
Peugeot T1 LOW
BP8140X5419755
7648140392
96 251 330 80
If someone can help me out, that would be great. Only have numbers 1-6 on front of stereo. At least i'll be able to pick up radio.. YEY ==================================
Duplicate request!
Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
Details as follows:
Peugeot T1 LOW
BP8140X5419755
7648140392
96 251 330 80
Post Number: 1 Registered: Dec-09 Posted on Tuesday, December 01, 2009 - 12:43 pm:
Hello hope u can help me find the correct code for my Megane Renault stereo. I've lost it. Here is the number. VFILM3HH76R552093 thanks ==================================== Please quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Hi, I'm new to this site, I just purchased a used BMW radio, and there is a message that says Code, the dealer wants to charge me 50 bucks for it, but I'm not even sure it works.
The serial Number is: CM5707 and the model is F70319641A
Please help if you can, thank you very much, my e-mail is Bagelpsychic@yahoo.com Thanks, Danny
hey ppl, need a code for renault megane scenic RNRD0440052697 FD0204060052697 U546 thanks a lot ----------------------- @Reg Rooster hey, 5475 didn't worked out.. maybe some other? ===================================
Check your numbers again
Is the last one U for UNCLE or V for VICTOR ?
If it is V772 .....and RNRD0440052697 is correct then your code will be 4472
Post Number: 1 Registered: Dec-09 Posted on Tuesday, December 01, 2009 - 07:38 pm:
Hi i need the code for my radio Serial:CLO158 P0004047 Model No:PN-9728F (some number engraved near the top right:3101527)
Im not sure but i think the make is a Clarion but it also says nissan on the tape flap. please help asap thank you very much. ===================================================
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then are you entering it correctly? --------------------------------------------- hey mate, rechecked all numbers, they're right. it's U546 and tried both codes, don't work. type the code, than confirmed, and none i don't know if this could mean something more model: RENRDW132-10 thanks a lot. regards
Post Number: 3 Registered: Dec-09 Posted on Wednesday, December 02, 2009 - 10:10 am:
------------------- Check your numbers again
If not then are you entering it correctly? --------------------------------------------- hey mate, rechecked all numbers, they're right. it's U546 and tried both codes, don't work. type the code, than confirmed, and none i don't know if this could mean something more model: RENRDW132-10 ===================================== The codes given have been checked and are correct. Providing you are entering it correctly (make sure you press and hold the final ( ) for at least 10 seconds ) then it looks as though your radio is either faulty or has been recoded to a completely different number.
Radio Decoder Service required...but won`t be free
Hey guys! Whether you could help me? I've tried to download lots of decoders and calculators, but couldn't find the right code. I've recently bought Audi Concert Plus, however there was no safe code neither with it or on it, maybe you could help me?
AUZ1Z3A9600177
7649246380
4B0035186E
That's everything i could find on my audi concert. I'd appreciate any help, there's no problem with my donation like beer or something to anybodys paypal as well! Regards from Lithuania!
Hello. I would like your help in unlocking my radio in my Honda Civic LX. The serial number of the radio I got: U2802 L8226 I would appreciate much if you help me take my music again. Should read the manual that this was going to disconnect the battery.
Thank you very much in advance, my email is cesarazmitia@gmail.com
Post Number: 1 Registered: Dec-09 Posted on Friday, December 04, 2009 - 12:52 am:
Thank you very much in advance, my email is cesarazmitia@gmail.com =================================== HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
Please note:
Unfortunately the majority of AUDI codes (including yours ) are not available for free from anywhere on the Internet. Tony New member Username: Tonislovas
Post Number: 1 Registered: Dec-09 Posted on Thursday, December 03, 2009 - 11:41 am:
AUZ1Z3A9600177
7649246380
4B0035186E ====================================
Unfortunately the majority of AUDI codes (including your radio made by BLAUPUNKT ) are not available for free from anywhere on the Internet.
